Brake pad replacement
#47
Has anyone tried putting the car in neutral? I'm wondering if you have it in neutral, chock the front, raise the back the wheel should spin freely. If it does then my only concern would be whether the piston is far enough retracted that it can fit over new pads?
#48
Looks like you have to remove the electric brake actuator and use a Torx 40 also called a T-40 bit and spin it while pressing in the caliper, Here are two Youtube videos showing it being done. Be careful not to damage the O-ring when removing the actuator.
Quantum501 (03-17-20)
#49
I did it without scan tool, and here is how:
put in park
While running, turn OFF the auto e brake
turn off the car
remove the negative battery cable and positive
remove rear wheels
disconnect E brake connection
Then replace as normal
I used the tool Torx to turn the piston as seen on YOUTUBE
put in park
turn off the car
remove rear wheels
#50
put in park
turn off the car
remove rear wheels
put in park
turn off the car
remove rear wheels
https://media-cf.assets-cdk.com/team...TG_Outline.pdf
#51
This is the NX procedure (which is very similar) note the verbage on page 4. It cautions that if you use a hex wrench to rotate that nut to release the brake, you have to replace the brake actuator o-Ring.
#52
I've done countless brake jobs on different cars but will be doing my '17 RX for the first time. Ordering new OEM rotors and pads all around. Anything else I should get? Shims are usually reusable at least once.
The electronic parking brake, anything around that I should know? It's always been a nightmare taking off rear rotors on other cars due to rusted parking brake. Never seen what this electronic stuff looks back there, hopefully it's not a pain to deal with.
Also, does anyone know the size of the bleeder screw on the rotors? I want to flush the system using a speed bleeder.
Thanks![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks
#53
Your best bet is to invest in the Techstream software, once you have that the rest is easy. Use the NX procedure above and chock the front wheels a leave it in park. Then you can remove one wheel at a time and chock the other . When you are done turn the ignition on and set the parking brake , you’ll hear the piston winding out till it stops , After the car is started the EPB will release and you are done.
#54
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/a00f1cd1_2ede_43b7_930d_4b7a5adec506_c42a285314d23b4bfa46f600b32ecec365e9cb1d.jpeg)
#55
This should work for our cars right? i wish i knew this before putting in new pads... would have save me half an hour.
DOES NOT WORK ON 4th GEN RX350!!!
The following 5 users liked this post by ghost31711:
bamalam (03-20-21),
daddiojigg (03-28-23),
eddie420 (03-20-21),
JJdog (03-09-22),
Lexspeed (01-26-22)
#56
Nice! Tried it on my 2018. After disengaging it, and then turning the car on again, as instructed, mine backed off the motor on the first pull of the button, and re-tightened on the first push thereafter. At least I THINK that's what happened. It's reset to auto and hopefully stays that way. But that's much more elegant than some of the home brew procedures that you can find.
#58
#59
https://www.youtube.com/watch?v=-Y1U8Iw88iA
Nothing like the good old days when working on cars was super easy.
#60
I saw this on YouTube yesterday.....safer than trying to wire it and kill a computer. I asked him about using the Torx fitting on back of the motor that I have seen some people use. He said don't do it manually bc it has to calibrate. I believe him, just wonder why it would not self calibrate when you re-engaged the system. I will use this video.
But there is no reason to do it that way if we can put it in service mode. Each EPB o-ring is like $3-4
There is an advantage to the EPB though. We no longer need special keys to push the caliper piston back,
