Brake pad replacement
#106
Hello again,
I am a Lexus Master Technician and I am creating a series of maintenance/repair tutorial videos covering the 2016-2022 Lexus RX models.
Here is my video showing how to release the electric parking brake to allow for rear brake pad replacement 2020-2022 RX models.
(This method will not work on 2016-2019 models, video on that will be coming in the near future).
#107
On my 2019 RX, Lexus Service advisor (who I trust) quoted $500-$600 to replace brakes and resurface rotors. Going to a reputable tire shop is almost 50% less.
Advisor stated, with brakes you get what you pay for, a tire shop is not going to use Lexus parts which alone is a big difference.
Would appreciate any thoughts or past experiences on this.
Thanks,
David
Thanks,
David
#108
So for $600 they are replacing brake pads is that front and back? How many miles on your car?
#109
I'm not a fan of resurfacing rotors. If they're bad, replace them.
#111
Thanks,
David
Thanks,
David
#112
I have a 2017 Rx350 that I bought CPO. I have had the front and rear brakes replaced twice now about once per year b/c they start vibrating excessively. The car has less than 80k miles. My mechanic uses OEM parts and has been replacing the brakes on his warranty but it’s not how brakes should work. I suspect the cause is that Lexus engineers designed everything to minimum gage to reduce weight to meet government mileage requirements resulting in rotors that are too thin to withstand the heat generated in routine everyday use. I’m a structural design engineer so I’ve seen this sort of engineering thought before. Has anyone else experienced this or have any suggestions as to how to break the cycle of constant replacement? Has anyone tried non-OEM rotors and/or pads? I appreciate any help or suggestions I can get. I will probably never buy another Lexus b/c of this issue. My 2002 Highlander that had 262k miles never had this issue.
#113
Brake pads get replaced because they wear thin not because they are vibrating. Why are they vibrating? Try a different mechanic.
#114
Brake vibration is most commonly caused by warped rotors. Rotor warp is most commonly caused by over-torquing the wheel lug nuts. Mechanics accustomed to servicing Detroit-designed cars will be shocked to learn that the Toyota/Lexus lug nut torque spec for RX 350 is 76 ft/lb.
Chevrolet/GMC wheel lug nut torque spec is typically 140 ft/lb.
#115
RHYS, It's not clear if you replace or machine the rotors along with the pads. Like others say on here, pads don't cause vibration, rotors do that. I had a 17 RX and never had any problems. I would say if you replace (no machining) the rotors and pads with OEM parts AND as dibl says, torque the wheels properly, I don't see you having any problems.
jcg0324 (06-08-22)
#116
Many times it's not warped rotors at all but rather pad material adhered to the rotors. I had that with my ES, a few good stomps on the pedal cleaned them up and they were good thereafter.
ravenuer (06-07-22)
#117
Thanks. I’ll pass that on to my mechanic and see what he says. He’s been taking care of my family 25 years and is a very honest guy so I don’t think he is the problem but I’ll ask him about the torque. Good advice!
#119
mikemu30 (06-08-22)
