Split screen on 2017 RX with Nav
I have the 2017 RX.
In the navigation, is there a way to have the system default to "turn by turn" directions. I appear to be stuck at default where it shows all of the exits.
In Map mode, the only possible selection is "map only", all others are greyed out.
Please help. Thanks.
I have the 2017 RX.
Last week I drove a 2017 RX with the top of the line package for Canada. Last year i tried a 2016 similarly equipped. One of the features on that nav screen that I have enjoyed since 2010 was that the system automatically went to split screen once on major highways to display upcoming exit ramp info that included time to ramp and distance, It would also display upcoming rest stops. My current 2013 RX displays that info as did the 2016 --and i did not have to program anything into nav for that to happen (ie no destination had been set) I tried to find that info in map mode and there was a section for "freeway exit ramps" but it was greyed out and i was not permited to activate it. Is this no longer a possibility or something that the dealer must activate? I have grown quite accustomed to this feature. Please advise as it could sway my decision to buy. Thanks
dentate
Oshawa, ON and
Port Charlotte, FL
dentate
Oshawa, ON and
Port Charlotte, FL
My 2016 goes split screen when on interstate/major hiways. Have you tried the 2017 on the interstate yet?
The user can choose to have full screen or split screen in the settings on either vehicle.
My point was that I drove the same route on both the 2016 and the 2017 RX - the 2016 automatically went to split screen on the major highways and displayed the upcoming exit info. In the 2017, I was able to select split screen, but all i got was either a compass or another smaller map. When i went into the map info area on the screen the ability to turn on "freeway exit info" was greyed out, not allowing me to select it - I even tried to do it while on the highway! I wonder if it has anything to do with the fact that Canadian versions do not have Enform --but that has not changed - we have never been allowed to have that.... Greg, when you have the split screen, do you automatically get the interstate exit info or do you have to select it? Any Canadian owners out there want to chime in? Thanks
dentate
Oshawa, ON and
Port Charlotte, FL
dentate
Oshawa, ON and
Port Charlotte, FL
When I select split screen, I get the exits info. I seldom use split screen though.
Wonder how we lived/drove vehicles without nav. system in old days. Technology makes people lazy and dumb by the day, LOL! Think about it we're all becoming button pushers like a robot.
ggebhardt (05-14-17)
Yes you can get split screen with exits. The owner manual makes it sound simple. The little grey boxes never work, so I know what you mean. I got it to work by accident by clicking on the intersection while driving....use the mouse, drag the pointer to the intersection and it should work. Make sure if there is a little grey exel type spreadsheet in the top right corner to click on that. That excel type box will disable how you view the screen/s
This is such a bad description but keep playing with it. Maybe get a passenger to play with it while you drive as that's the only way to do it safely.
On a side note the salesman couldn't make it work either...My better half figured it out.
dentate
Oshawa, ON and
Port Charlotte, FL
dentate
Oshawa, ON and
Port Charlotte, FL
dentate
Oshawa, ON and
Port Charlotte, FL
dentate
Oshawa, ON and
Port Charlotte, FL
Is it greyed out because you tried to change it while rolling? Settings are not allowed to be changed when on the road. I guess they don't want it to distract us and cause an accident. You need to be parked to change settings.
I did not check on my side, but I noticed that when I tried to manually connect my phone. Then I saw also that many settings are greyed out.
I have 2016 RX 350 Luxury package.
PeeVee
I tried it both while parked and while driving. It is the executive pkg. that I drove in both the 2016--where it did work and i did not have to do a thing to make it do so and the 2017 - where no amount of fiddling seemed to have any effect. Unfortunately, I only had the dealer demo for the day last week (very generous for them to do so) so i have no ability to play around with it now...but just wanted to make sure it would work. Interesting to note that today I have the 2017 NX Exec package and it worked the moment i went on 401.
Fast Ford
Thanks for the descriptors of what your better half had to do...Now, does it work automatically or do you have to fiddle with it each time?
dentate
Oshawa, ON and
Port Charlotte, FL
Fast Ford
dentate
Oshawa, ON and
Port Charlotte, FL
