Mark Levinson 15 Speaker System - Best Sound Settings?
I have ipod set to flat on the equalizer. With that setting I have the Treble +1. Mid -1 and Bass 0. This has the most natural sound to my ears. However, I also have a dedicated amp'd JL Audio subwoofer that has it's own volume control.....
FSportWaxy (07-06-17)
What makes those settings the best? The treble is overly shrill. It sounds washed out.
It took me a few weeks of driving to setup the audio settings for all inputs. The best setting is what you ears love the most.
Everyone's hearing is different. Just play around with what works best for you.
Ideally, soundstage in a concert, the sound is coming from in front of you with the bass response all around. You should never hear the sound behind you. Also, the ML tweeters are really sharp so keep that in mind.
It also depends on the type of music you listen to. I like house, pop, etc.
Take the time to listen to each type, low, mid, high and find the baseline. Then do minor adjustments as you drive.
https://www.crutchfield.com/S-KnIWTd...ealSystem.html
https://www.crutchfield.com/S-LEqGGn..._car_tips.html
So you haven't adjusted the settings at all between a wired connection vs. BT, Satellite, etc. ?
https://www.youtube.com/watch?v=cSGz2T-Dby0
I am an advance amateur musician(low brass-euphonium). We listen to different musc, we have different taste. You'll have fine your onw setting for your liking
It is great that SAT, FM, AM, etc have separate settings.
I find I need to bias the sounds way to the rear and crank up the volume for best results or all sound comes from the front of the vehicle. Then I adjust each to my tastes.
Love the ML radio.
Love the ML radio.
FSportWaxy (07-07-17)
nope. I guess the older I've gotten I don't care as much. Plus sat always sounds terrible so I don't even bother. Hd radio and USB sound great to me and are the most freq sources I listen to.
Guess I'll be getting an iPhone next!
