Carplay Install
Old 07-28-17, 06:50 PM
lilboi
lilboi's Avatar
Default Carplay Install
Still waiting to get everything installed but I have all the functional pieces purchased. Will update this post accordingly as I progress.
Why
I am not a fan of the nav interface on the RX. I find the remote touch very hard to control (even when the feedback is dialed). More so, the navigation seemed to be hard to use (e.g. entering an address was not seamless).
I wanted to find a better solution and there doesn't seem to be any native solution. I was able to piece to gather a few pieces that I think I'll be happy with.
Experience Summary
I was able to get CarPlay working with the original Nav display; however, the controls for the CarPlay is using a separate controller which isn't too bad. It's also not using the original mic but a different one that is wired to the CarPlay interface unit.
Parts
Beat-Sonic Navigation and DVD Control Bypass Module - NDS6223EP
CarPlay Interface (with steering wheel remote)
3.5mm to Component cable 3.5mm to Component cable
RCA Coupler RCA Coupler
Standard iPhone Cable
Install
Will specify more on how I wired everything up and hid the components once I have it all installed. Currently, I just tapped off the cig lighter and plugged into the AUX port to test the interface. It works!
Pictures
Old 07-28-17, 07:40 PM
aznkorboi
aznkorboi's Avatar
yay an actual first useful mod
Old 07-29-17, 09:57 AM
radium22
radium22's Avatar
Nice! Android Auto can be installed the same way, right?
Old 07-29-17, 10:21 AM
lilboi
lilboi's Avatar
I would assume so but you'll need to find an android auto module interface instead.
I fully installed it this morning. Will report back on how well it works once I take it for a drive.
Old 07-30-17, 01:04 PM
Hubs
Hubs's Avatar
How much time did it take for you to install?
Old 07-31-17, 06:34 AM
aswang
aswang's Avatar
Very nice, thanks for sharing this. Will look forward to your detailed write-up!
Old 07-31-17, 11:52 AM
jwong77
jwong77's Avatar
Very cool! Looking forward to the write up as well! Just wished there was a way to use the car's built in controls instead of having a separate remote, but otherwise, that looks really well integrated.
Old 07-31-17, 07:11 PM
t4tran
t4tran's Avatar
The link to aliexpress does not work.
Old 07-31-17, 07:14 PM
UKEE
UKEE's Avatar
https://www.aliexpress.com/item/Gene...812219129.html
Old 08-01-17, 06:49 AM
aznkorboi
aznkorboi's Avatar
I want and need to do this badly.. How come your right side display with the temp etc is all grayed out? Any issues with the current navi system controls etc?
Make some vids and photos when you can! Thanks!
Old 08-01-17, 05:26 PM
lilboi
lilboi's Avatar
I was in ACC. I didn't start the car.
Old 08-01-17, 05:30 PM
lilboi
lilboi's Avatar
So I've been running it for a few days. Still doesn't seem natural and in most cases i may just lean on bluetooth for music. But the times where I may be on a longer trip, I can find this being helpful.
The install took about an hour. Actually the hard part was the BeatSonic Nav Override Unit. The airplay was dead easy.
I'll post a few more pictures of it running and how the interface looks like when I pull the pictures off the camera.
The unit does seems a little buggy. I notice the other day it didn't charge the phone. In terms of quality and experience, I'd give it a 3 / 5. It would go to 4.5 if I could use the remote touch and steering wheel controls.
Hubs (08-07-17)
Old 08-01-17, 05:31 PM
lilboi
lilboi's Avatar
I should also mention that it allows you to have another AUX input. I plan on wiring a front camera to this.
You can switch inputs by holding the down button on the controller. Really handy.
Old 11-11-17, 09:26 PM
gauravsacc
gauravsacc's Avatar
I found this android interface which I want to install. https://www.aliexpress.com/item/Car-...829108372.html
It does promise steering wheel control. Anyone else tried this?
PeeVee (11-13-17)
Old 11-12-17, 03:22 AM
JSracer
JSracer's Avatar
this is what has my interest, Beat-Sonic IF-04EP Smartphone Mirroring Kit for Lexus but i might be a tic gun shy to rip apart a 65k rx right away to see my phone screen.
we currently use garmin friction mount in both our current vehicles on the dash that hold our phones well. (not sure if that will leave a mark on the new dash)
http://www.beatsonicusa.com/if04ep.html
Amazon Amazon
Quick Reply: Carplay Install
