What fuel grade are you using in your RX350?
#393
#394
#395
I watched a recent episode of Engine Masters on TV and that was about using different octanes, started with 87 then drained it out and put in 91 then drained it out and went to 110,, rain the engines on a test stand and the curves of HP and torques didnt change.. Was w/n, 1HP didnt knock..and ran the timing at 29 degrees on them all...
#396
#397
There is nothing about the F-sport package that deals with the engine so that's a rather silly thing for a dealer to say. It's a handling and appearance package and has nothing to do with engine tuning.
If I were to summarize the many pages of this thread in a sentence, given the parameters outlined in your manual, go with what suits your budget and drive feel.
The following 3 users liked this post by 1Louder:
#399
#402
If your engine does not knock at 87... then it does not need it
Of course one test, just like my one experience it does not mean it applies to the masses, but both on my vehicles, the V6 suv and the FBO is350 run way better on 93, feels much smoother at idle, less throttle input when changing lanes, and zero pinging, etc.
Yes, I do sometimes go cheap on 87, just to see if maybe is snake oil effect, there is a power loss on both V6s and I mean slightly sluggish across the powerband. I have no machine or special electronic device as proof, and I could be wrong. The highway drives across the city shows otherwise, engine is responsive, smoother, I can feel it struggling less.
Just a quick observation about the videos, many ECU take a few miles to be running the specific fuel to re-learn and calibrate. Dumping fuel and putting the next octane rating seems it is not giving the ECM enough time to recalibrate, maybe could be the case on their test. Would have been great run the tests as well on an engine running its accessories.
To each its own, I know I will stick w 93 here where I live. Let me finish with, and this is where maybe some say they run 87 no problem. In FL I rarely used 93 because 87 was super good w the engines (only used 93 on a boosted modified car), but here in the Central States, any lower than 91 is very low grade fuel, maybe at Shell and still.
#403
this 4th gen RX been out since 2016 and this engine has been out (with some modifications) since 2002 (2grfe) and we are still having this conversation...
use 87. if you want to use higher octane go ahead but it doesnt require it. Its an RX, not a RC-F. it'll run 87 no problems
I havent heard of anyone having engine problems on the 4th gen RX due to bad fuel, or lack of octane and we have guys running with 2016's w/ over 150,000 miles on the odo.
ravenuer (09-10-22)
#404
My SUV is much older than the RX, it has a V6 Toyota engine. I never said using 87 will harm the engine.
Statistics show around 127,000 convenience stores selling fuel to the public in the US.
The YT posted video tested one type of 87 fuel. It would have been more valid if they had gathered samples from different fuel zones of the country and check for discrepancies/consistencies, but that is somewhat unrealistic resulting in a very long video.
I did mention that in FL I always used 87, it was that good, I could tell when driving, idle, high speed, acceleration.
It is possible for some the lowest grade will suffice and the RX will run perfectly fine.
In FL I felt using 93 was throwing money away, only used it for the modded boosted 1.8L. The wideband AFRs, timing, spark plug readings and pinging would let me know the higher octane rating.
Where I live now, using 93 is NOT throwing money away for me, all the V6 and turbo engines of my cars, once again, run smoother, idles much better mostly so when the A/C is on. (all vehicles maintenance up to date), and run top speed effortless. It does not mean using 87 will harm the engine, in my specific situation. Test for yourself, maybe in your neck of the woods they will all deliver the same results regardless.
cheers
cheers
#405
They said if you're NA, octane doesn't matter. What about turbo engines?
