What fuel grade are you using in your RX350?
#77
#78
Lexus manual recommends ANY type of fuel rated 87 or up on American fuel grading scale. So, yes the Lexus Canada recommends 87 fuel and it is printed in my manual black and white. Lexus Canada also claimed that using higher grade fuel will NOT extend the life of my 2017 RX V6 engine (page 678 of the manual).
My 2017 Canadian manual only says "Select octane rating 87 (Research Octane Number 91) or higher."
#79
After reading this thread I filled up with 93 a couple of times (I've always used 87 thus far) and I honestly don't notice a difference. Both averaged the same MPH and the car performed smoothly regardless of the octane rating. I guess it comes down to personal preference.
#80
This, which gas to use, is almost a religious thing.
#81
Even better, I drive with regular in both of my Lexuses and every 3-5,000 miles I throw in a bottle of Techron which costs about the same as the cost differential between just one tankful of premium over regular.
Cocal (01-23-18)
#83
I've done that with my Toyotas, never had a problem with them.
#85
This reminds me of Fabio not believing it's butter. And spring water versus artesian water.
If there's a decrease in performance from using 87 octane gas, the owner manual wouldn't even recommend using 87. Owner manuals are very specific and it'll state that it needs 91 octane or higher, just like the RX450H and IS200t manuals. The IS200t also has a sign that says to use premium fuel next to the gas cap.
A previous poster wrote that turbo-engines need higher octane gas. That's definitely true. Using lower octane gas in a turbo-charged engine that requires premium fuel can cause engine knock. Engine knock is like the grim reaper saying hello to your car.
#88
If you drive 12K miles a year, at 20 MPG you burn through about 600 gallons of gas. So, by using regular gas instead of premium you are saving around $120 per year. Is it worth it? I don't think you can hurt anything by using regular, but there is a reason why Toyota recommends premium gas.
#89
If you use as recommended a top tier regular gas (I use Exxon) which should have the proper amount of additives in the regular blend then you shouldn't have a problem. I use Techron (from Costco) every 3,000-5,000 miles just as cheap insurance. I would, however, be reluctant to suggest using it less frequently (once every year or so) since it might free up larger deposits that could impact the injectors or oxygen sensors. It may very well be a coincidence but a few years ago when I used Techron on a 2007 RX for the first time after about 50,000 miles I had an injector failure immediately after. Might not have been related, of course.
#90
http://lexus2.custhelp.com/app/answe...xus-vehicle%3F
