What fuel grade are you using in your RX350?
#122
If it had the capability to change the tune on the fly, it would be stated as such. It would be a marketing tool. 87 octane is what is recommended. There, I just said it!
#123
If it still knocks then you may have other problems (Plugs, carbon etc)
#124
#125
True as well. Your car's computer will limit performance, but no harm to engine. The potential for engine knock is from using lower octane gas with aftermarket turbo chargers. Cars with OEM turbo engines like the IS200t will have the computer limit performance as well, but I would never put in 87 since the owner manual recommends 91 or higher
Cocal (01-24-18)
#126
#129
Ok.
Here is what I got from Lexus Canada.
Loud and clear
So you won't get the advertised 295hp and 268lb-ft unless you fill up with 91 octane.
Everyone who said the manual was clear and it recommends 87, you were interpreting incorrectly. A clear manual, one should not interpret.
In fact your RX350 is designed to use 91 octane premium fuel and retards the ignition timing to prevent knocking when you fill up with regular (87).
Loud and clear
Thank you for your recent enquiry.
Please be advised that your Owner's Manual states the minimum fuel requirement for your 2017 RX 350 is Unleaded gasoline with an Octane Rating of 87 or higher. For improved performance, the use of gasoline with an Octane rating of 91 or higher is suggested.
Please be advised that all tests and vehicle specifications for our Lexus vehicles are done using 91 Octane fuel.
Thank you once again for taking the time to contact us. We hope this information has been helpful.
Regards,
Jessica xxx
Customer Assistance Centre
Lexus Canada
Regards,
Jessica xxx
Lexus Canada
#130
Ok.
Loud and clear
Loud and clear
In fact your RX350 is designed to use 91 octane premium fuel and retards the timing to accept 87 when you fill up with regular.
What I've been saying all along. If anything what's been written on the manual is a WARNING not to go below 87 octane and NOT a recommendation.
#131
There's a reason these threads keep getting closed. It's almost political. At the end of the day, you can't go wrong with any fuel with an octane rating >86. All owners are free to spend their hard earned money as they see fit. Even if you did gain 10HP running premium, remember, you're still driving a slow SUV.
#132
No, I don't play soccer!
And the thread is in danger of being closed again. Any time this topic came up in the 3RX forum, the phrase 'beating a dead horse' was often said.
Agree to disagree and move on.
#133
In Australia the manual is clear, use RON 95 (90 AKI for US) or you can temporarily use RON 91 (87 AKI for US). The filler flap also has a red sticker saying Premium Unleaded Fuel Recommended.
Oldfart (01-24-18)
#134
Yes,It’s a marketing gimmick somehow they get away in North america.
Make us believe that it’s a better buy compare to European luxury SUVs that require Premium.
At least Honda “used” to state the difference. Not sure if they do anymore.
mssca (01-25-18)
#135
Because obviously there is a performance increase ... and in the European and Australian markets only premium is recommended . It’s interesting that the only country in the world that says they have problems with hesitation and harsh running is the USA, where many people seem to insist on using standard grade fuel . The problem doesn’t exist in any other market when premium fuel is the only one used .....
