TPMS programming for second set of wheels?
#46
I think there is a bit of confusion. You can reprogram the TPMS yourself, but you need the dealer's help if you need to recalibrate them.
In the OM there is the way to re-program them.
Also these TPMS have batteries and they don't last forever, so it may be a case of dead batteries in which case you need new ones.
#47
Before shelling out big money to have the tires broken down to manually read the ID of each sensor, you may want to check around with a few local tire vendors. Canadian tire, Discount tire or even a local tire shop? Many have tpms tools which can read the sensor IDs while on the car, then the tool either stores the IDs and it’s plugged into the aldl of your car and uploads sensor IDs or they can record the Ids and program them in using a scan tool. I personally have techstream knockoff, which can program in new or seasonal change IDs, many aftermarket scanners can do this as well.
#49
This sounds fishy to me. Any dealer should be able to read sensors on the car; they should have the tool for that. Unless it's because the sensor batteries are toast. If they don't/can't read "good" sensors, I'd run. Perhaps they are trying to get $$ out of you? How much are they going to charge?
I have the Ateq tool. It allows you to program the car for the specific set of tires/sensors you want to mount, seasonally. I am having issues, though, as the summers won't show the current pressure on the dash display. Idiot light is not illuminated, So I am going to my local Toyota store next week to have them reprogram the system. They will read the summer sensors, on the tires, reprogram the car and I should be good to go. They will also give me the codes for the 4 sensors, which I will load into my Ateq tool for next year. I took delivery last November with the winter tire set on the car and have those codes programmed into my Ateq tool. The display did show the pressures for those tires all winter.
I'm going to the local Toyota store because it's closer and 1/2 the price of the Lexus store. I'm going to pay $34.95 for this.
jollick (04-23-21)
#50
It would be interesting to lower the pressure in one of your tires to 10 psi and see if the car can tell?
#51
Hey, I'll provide an update.
Took it back to the Lexus dealer because they were puzzled. After about 30 minutes they fixed it.
Turns out the Toyota dealer had added a..."5th tire code" to the wheels. They deleted the code and things went back to normal.
No idea why the Toyota dealer did that.
Very pleased with my Lexus dealer though. Definitely took care of it. And I think the Toyota service was fine as well. Just probably a sleepy tech.
The following 2 users liked this post by notasubaru:
exonw (05-10-21),
frankymenz (04-27-21)
#52
Have another question for the experts on TPMS here. I have 2 sets of tires/wheels with genuine Lexus sensors for opposite seasons. Just had the winter set installed and reprogrammed by the local Toyota store (long story, won't bother you with that). The advisor said it doesn't matter which wheel ends up where on the car, as long as the car is programmed to read the codes, it (the appropriate computer) will figure out which corner which sensor is at. Does that make sense to you folks? I would have thought one would need to tell the car which sensor was where as the tires are rotated seasonally.
#53
#54
bamalam (11-22-21)
#56
This is an old thread. I need to ask if anyone knows how to reprogram TPMS on my 2022 RX450h. I have one set of OEM 20" wheels that came on the vehicle, and one set of aftermarket 18" wheels with high profile winter tires. I purchased OEM TPMS transmitters for the aftermarket wheels from. Bought the wheels and tires from Discount Tires. They were able to reprogram the new TPMS monitors and the individual tire pressure read out worked great.
Then I moved from CA to PA. [size=13px]No Discount Tires within 200 miles.[/size]
Last week I took RX into the dealership and asked them to swap out snow tires and wheels for summers. $60 to swap out the wheels and $80 to reprogram the TPMS !! I told them no thank you. [size=13px] [/size]
I then swapped out the wheels/tires to the summer set in my garage. I bought a 2023 Autel TPMS Relearn Tool TS408 from Amazon. It would not reset the TMPS codes so I sent it back.[size=13px]I took the vehicle to a local tire shop to reset the TPMS. I told them they will have to use a reset tool that plugs into the OBDII. They said they did but it didn't work.
SO, does anyone know if the 2022 RX450h will carry two sets of TMPS monitor codes in the computer? If so, how does one switch from one to the other. The last entry into this thread about an NX looks promising. I tried to follow the direction in my Owners manual and just hold the reset button in once. It said they were reset but it didn't work.
Second, if a 2022 RX450h cannot store two sets, is there a way to switch from one set of OEM TPMS monitors to the other without having to pay the stealership?
Thanks
John
I had to take it to the dealership and pay the big buck to do a job that took them all of 10 minutes. [/size]
Thanks
John
#57
RE: OEM TPMS monitors to the other without having to pay the stealership?
I run 2 sets of wheels and tires (1 OEM, 1 Aftermarket) on my daughter's 2016 RAV4 and my wife's 2020 RX-L.
I use the Autel MaxiTPMS TS508 each time I switch summers to winters or vice versa. It's not the most intuitive tool when used 2x per year, but I wrote out my specific procedure to save me from using the manual each time.
The procedure I use is to "relearn" each sensor with every wheel change - a 5-minute process of going around the car and using the tool to scan each of the four "new" sensors and write them to the ECU via the OBDII.
Was it intuitive to figure out which procedure to use with the Autel tool? Initially no. Could my cars store both sets of sensors so I don't have to re-scan each time? Maybe, but not in my experience. Is it "a pain" to use the scan tool now that I know what to do? No. It's 5 minutes. And it paid for itself in one year vs. the $tealer.
My $.02.
My $.02.
#58
Thanks for your experience. The TMPS tool I bought, 2023 Autel TPMS Relearn Tool TS408, also had a relearn function described exactly as you described above. I agree that the instructions are not very good. Comes from translating from Chinese to English. After several attempts to get it to work I finally got to the point where it was ready to relearn the codes and it gave me an error message saying that my TPMS sensors (ordered from Lexus) are not compatible with reprogramming to a new code.
#59
That's crazy if Lexus is providing a sensor that's not compatible with a tool like the one you had. Like Apple preventing non-Apple cables from working with an iPhone.
I guess I'm lucky the OEM sensors (2016 and 2020) are compatible with the tool. I hope you get a better answer than mine.
#60
Thanks
John
Thanks
John
https://m.youtube.com/watch?v=oCM6G03UsUs&t=84s
ravenuer (03-26-23)
