Set drive mode default up on start up
As an alternative you can use the customize function instead to dial into the same as sport mode. Then all you have to do is push down on the **** instead of turning it to the right. I find it easier to turn on and off that way.
GSFRX350 (08-04-19)
cool - how do you do that and then how would you put it back to normal in that case?
https://www.clublexus.com/forums/rx-...rive-mode.html
but basically it's in your manual. You just press down to change it to the custom mode and press it again to go back to normal.
I only found 1 thread about it here
Cocal (06-07-20)
RX350L Econ Mode
Have the RX350L 2019 a little over a month and didn't take me long to really dislike the econ mode. The steering is unresponsive with too much over correction and starting out in 2nd gear feels extremely sluggish. I now only drive in the Sport mode. It would be nice if that could be set as the default. Am I the only one noticing this?
I wish there was a way to make sport the default, but there isn't.
There may be a gadget that attaches to the OBDII and makes the computer remember the last setting and keep it, a friend of mine just got one from Russia for his MB to stop the engine stop & go and it works flawlessly.
There may be one for Lexus, perhaps a search will tell you.
