Service Intervals/Requirements
This routine has got me through over one million care free miles with not one problem. Every 10,000 miles an oil change and tire rotation is needed. At the Lexus dealership this should be less than $100. Every 30,000 miles the brake fluid needs to be changed and again about $100. Every 20,000 miles change the air and cabin filters. This combined takes five minutes and the air filter can be bought on line at Lexus Parts World for $18. The cabin air filter can be bought at Walmart for $18, It is the Fram Fresh Breeze #10285 with carbon and baking soda to filter the air. Wiper blade inserts again can be bought at Lexus Parts World for $20 for both refills and takes five minutes to replace. You are done until 100,000 miles. At Lexus Parts World use cl5 in the promo code for 10% discount. If you go in and ask for the 10,000, 20,000 30,000 maintenance you will be paying big bucks for a lot more items you do not need checked and inspected. Once a year replace the key fob battery cr2032. Keep receipts for everything. I take my oil filter and 5 quart jug of Mobil 1 purchased at Walmart for $24 to my local Toyota dealer and they charge me $20 labor.
The transmission fluid does not need to be changed. Posters will tell you different. I listen to my local Lexus Service Manager who wants my $$$. He said it never needs changing to the point that could cause more harm than good my changing.
The following 10 users liked this post by Freds430:
artem123 (03-21-21),
Dinesh2023 (07-23-23),
Marqevans (11-10-20),
My450H (12-24-23),
oespinoz (10-14-23),
and 5 others liked this post.
Why does the brake fluid need to be changed every 30K? That sounds like a service dept selling a snake oil to me, I have never heard of changing brake fluid in anything unless replacing a master cylinder, or corroded lines.. But thanks for the other info.
The tire rotation pattern depends on the tire type. The "drive axle straight back/crisscross the others" pattern
is best because all tires end up working every position and can be used on FWD/RWD/AWD chassis. The
obvious limitation is that you can not use this with Unidirectional Tires which must be kept on the same side.
Staggered fitment (larger rear tires) eliminated the ability to rotate at all...
they claim it absorbs moisture over time and will corrode the lines. I know folks who go 300k miles in fleet vehicles and never change it with no ill effects.
Oldfart (12-20-17)
The transmission fluid does not need to be changed. Posters will tell you different. I listen to my local Lexus Service Manager who wants my $$$. He aid it never needs changing to the point that could cause more harm than good my changing.
Dap04 (11-27-22)
Brake system should be a closed system, i don't under stand how it would absorb moisture as long as the lines are never broken, and one doesnt add water into the fluid resevor... But thanks for the info.
I just think they've extended the intervals in an effort to make the product seem low maintenance. And does the filter continue performing through 10k miles is another concern.
I guess that could depend on the size of the filter. I have not seen it yet, but if it is a little filter that looks like a 6oz pop can then i would be with you on the concern. If it is a larger one that looks like a can of Fosters Beer then i would say it can handle the longer interval...
memacman (06-24-23)
IMO if you plan to keep this car for 200-300,000 miles than yes 5,000 miles. If you trade in or sell it under 150,000 miles than could be overkill for you but not the next owner.
memacman (06-24-23)
RaiderHawk (03-25-24)
