Service Intervals/Requirements
Old 02-11-23, 01:24 PM
  #331
dibl
dibl's Avatar
Originally Posted by jcg0324
This would apply only to AWD vehicles....
That is correct -- I should have clarified that. But a lot of RX owners have an AWD. As far as documentation, it's in the owner's manual (for AWD models). And numerous other places, as per the Bridgestone site.
Old 03-03-23, 10:37 AM
  #332
rdfish1
rdfish1's Avatar
Default What maintenance should I do at this stage?
Hey folks, I have been unable to locate my owners manual for some reason so I’m turning to you for advice on what you think I should have done as part of my next service. This is a 2017 RX 350 with 45,000 miles, original owner. to date, the only thing I’ve done is change the oil every 5000 miles, put a new set a tires on about eight months ago and a new battery not long ago. So, question is, without looking at the manual I’m wondering if it is time to get the transmission fluid flushed, the brake fluid flushed, in addition to my oil change that is now due. The car is in outstanding condition, always garaged and well taken care of so there are no known problems or issues, but since I intend to continue to keep it for several more years to come, I’d like to go ahead and get done whatever should be serviced. But, not wanting to do more than is necessary. I’m also wondering if I would be better off having the Toyota dealership do this service and whether that might be less expensive
Edit. I did the cabin filer recently too.
Old 03-03-23, 11:06 AM
  #333
Freds430
Freds430's Avatar
Received 1,155 Likes on 746 Posts
2017 RX450h with 81,000 miles. I change the oil every 10,000 miles, cabin and engine air filters every 20,000 miles, brake fluid flush at 30,000 miles. That is it until 100, 000 miles when anti freeze needs to be changed.
Old 03-03-23, 12:47 PM
  #334
Quantum501
Quantum501's Avatar
This is the schedule that I follow and is mostly based upon the maintenance manual. I believe that you can download the maintenance schedule manual online at Lexus, but I prefer to do the oil sooner and the transmission fluid (1 drain and fill every 60k....not a flush. Lexus will tell you to not do, but even they do if the owner tows, so 60k is perfect time for a single drain and fill). Just an FYI that mine is a 2020 but most if not all of the specs and parts should be the same.
The following 2 users liked this post by Quantum501:
ravenuer (03-03-23), Trademan82 (04-24-23)
Old 03-11-23, 09:05 PM
  #335
ghost31711
ghost31711's Avatar
Put in a new engine air filter, change it between 25k-30k, change spark plugs at 60k, flush brake fluid as soon as convenient. I recommend a transmission fluid drain and fill.
Old 03-12-23, 03:47 AM
  #336
jcg0324
jcg0324's Avatar
If you don't care to read the owners manual, try browsing this web page: https://www.youtube.com/c/TheCarCareNut?app=desktop
You will find an expert opinion on how to maintain your Lexus/Toyota.
Old 04-24-23, 07:17 AM
  #337
Trademan82
5th Gear
Trademan82's Avatar
This!
I've followed his guides for DIY oil, trans fluid and coolant changes for my '17 ES350, and will soon be doing the same work on my wife's '18 RX350, as it's at 60k miles.
Old 04-24-23, 09:27 AM
  #338
golferjack
golferjack's Avatar
"Originally Posted by rdfish1
Hey folks, I have been unable to locate my owners manual for some reason so I’m turning to you for advice on what you think I should have done as part of my next service. "
Might try downloading the manual.
daddiojigg (07-23-23)
Old 04-24-23, 09:50 AM
  #339
mikemu30
mikemu30's Avatar
Received 2,560 Likes on 1,824 Posts
Engine air filter if not already done. My wife's 17RX has nearly 80K miles now and not much more than oil and filter changes, cabin filter every 10K, engine air filter every 25K and we've replaced the tires and brakes on all four wheels once.
The following 2 users liked this post by mikemu30:
Freds430 (04-24-23), ravenuer (04-24-23)
Old 04-24-23, 02:21 PM
  #340
Freds430
Freds430's Avatar
Have same car 81,000 miles. Oil change every 10,000 miles, brake fluid change at 30,000 and 60,000 miles. No alignment and perfect tire wear. Change oil and cabin filter every 15,000 miles sure way early but cheap and easy to do. That is it.
Old 05-28-23, 02:38 AM
  #341
goodyrl
goodyrl's Avatar
Default 2018 RX350 Required Maintenance
All we’ve ever done on our Lexus is Oil Changes & Tire Rotations
At 42,000 miles what if anything are mandatory service requirements? Thanks very much
Old 05-28-23, 03:40 AM
  #342
jcg0324
jcg0324's Avatar
You are way overdue for an engine and cabin air filter. All of this information is in the owners maintenance manual. For other useful service material, refer to the link at post # 336.
Old 05-28-23, 04:05 AM
  #343
Quantum501
Quantum501's Avatar
and go to post #334 for a spreadsheet listing everything
jcg0324 (05-28-23)
Old 05-28-23, 01:16 PM
  #344
goodyrl
goodyrl's Avatar
I apologize I did the air and cabin filters myself at 20,000 & 40,000 miles
Thsnis
jollick (05-28-23)
Old 06-21-23, 06:14 AM
  #345
TriC
TriC's Avatar
Default What Do You Think of This Service Estimate?
Took our 2019 RX 350 to the dealer yesterday to address brake pedal pulsation. The car has 13,600 miles with an in-service date of 9/26/20.
Just received a text estimate that the following "repairs" are needed:
$99.95 - front brakes pads at "5 mm plus" should be replaced because once the rotors are resurfaced the rotors will go bad again if pads not now replaced;
$104.44 - replace wiper blades;
$114.32 - replace cabin air filter;
$86.99 - replace engine air filter;
$149.95 - 4 wheel alignment; and
$206.05 - replace brake fluid.
Quick Reply: Service Intervals/Requirements
