Changing # of Blinks for Lane Change Turn Signal
Just in case some of you want to change the number of blinks when you tap the turn signal stalk for lane changing, here is a step-by-step posted on the 4GS forum (by: FishBike). You can have the dealer change it, or use an app too.
1. Start with the car completely off
2. Use the rotary **** on the wiper control to set how many blinks you want. This **** has four positions:
- 1st (bottom) position = 3 blinks
- 2nd position = 5 blinks
- 3rd position = 7 blinks
- 4th (top) position = no automatic blinks
3. Hold the wiper lever in the all-the-way-up position, and keep holding it there
4. With foot OFF brake pedal, press the start button twice so the gauges light up (keep holding that wiper lever up!)
5. Continue to hold the wiper lever all the way up for 5 seconds or more (if you go too fast you will have to start all over!)
6. Let the wiper lever come down one position and hold it there for 5+ seconds (don't let it go back to the middle, just let it come down one position)
7. Hold with wiper lever all the way up again for another 5+ seconds
8. Let with wiper lever come down one position again, and hold it for 5+ seconds
9. Let go of the wiper lever. The right turn signal should flash once. If it doesn't, turn the car off and start again at step 1.
10. Briefly move the turn signal lever down 1 position and let go of it again.
The left turn signal should flash to confirm your setting, but not in the way you might expect. It will blink 1, 2, 3, or 4 times to match where you set the rotary **** on the wiper control, so:
- 1 flash = set for 3 blinks
- 2 flashes = set for 5 blinks
- 3 flashes = set for 7 blinks
- 4 flashes = no auto blinks
Pug20G (02-05-22)
Thanks! Great info! (and in Japan, we don't have the app to change these settings, so it's extra useful)
But my god… Makes you wonder what's behind the decision not to just have the settings in some misc/advanced options part of car's navigation.
Somebody had to program this contraption nonsense as well.
Hi guys!
Yes, our app has the ability to change the number of lane-change turn signal blinks, but we have not yet tested that with a 4RX. If any of you already have an OBD adapter, would you mind sending us debug data from your RX, so we can confirm that that feature is supported and potentially add additional features? Thanks very much!
Once you have the adapter and the app, here's how to send debug data: http://www.caristaapp.com/help/faq/#debug_data
P.S. Carista is available in Japan, too!
Oh that's nice!
Does Carista OBD adapter work fine with Lexus G-Security in Japan?
All adapters I saw on sale here (basically, just a couple of local brands), were marked to disable G-Security system on Lexuses… Asking dealer, was told that G-Security disables itself if anything is present in OBD port (since the car considers itself being in maintenance mode…)
Not a car person, so I'm not quite sure what I'm talking about, but OBD adapters disabling at least some of security features on Lexuses in Japan is the fact…
Oh that's nice!
It looks like there might be another way to change it. #19 on the Personalized Settings sheet says you can change it in the navigation system. I don't have an RX to try it out on (it's supposed to be in this Friday!) so this is all I have to go on.
<a href="http://www.lexus.com/pdf/service/RX_with_nav_LPS.pdf">www.lexus.com/pdf/service/RX_with_nav_LPS.pdf</a>
What kind of problem are you having. Mine has run great. Only complaint I have is in a mild acceleration from a stop the vehicle has so many gears that it feels like it is not sure which gear it should use sometimes.
Having this problem https://www.clublexus.com/forums/rx-...-chirping.html
Oops. This doesn't work. I thought the turn signal and the wiper stalks on the RX and GS were the same. Sorry.
MODERATOR. Close thread due to inaccuracy.
