Fuse Box Locations
Old 12-01-20, 08:07 AM
ejisfun
ejisfun's Avatar
Originally Posted by jonnyyaa
hi, Im installing a a119 v3 and need to know what to tap into for buffered parking mode. anyone ? thx...
Have a look at my post here: https://www.clublexus.com/forums/rx-...l#post10842122
Old 01-02-21, 09:50 AM
PotOdds
PotOdds's Avatar
Default Viofo A129 Pro Duo 4k
Hi ClubLexus,
I'm just getting around to installing my Viofo A129 Pro Duo that I bought during Black Friday deal. I would like to get the parking mode properly setup with a fuse tap.
I have a 2018 RX 350 F-Sport.
Couple of questions,
- HK3 ACC Hardwire Kit. Which fuse tap should I get? ATS? ATC? MINI? MICRO2? I don't want to have to buy the 4 pack ($15.99 vs $5).
- What is the recommended fuse to tap in the fuse box?
If anyone knows of a simple YouTube video to follow, it would be appreciated.
​​​​​​​Thanks,
Old 01-02-21, 10:42 AM
PotOdds
PotOdds's Avatar
I found this thread. It looks like it's the low profile mini fuse.
https://www.clublexus.com/forums/rx-...l#post10893495
Comparing it with the Viofo diagram, it looks like the one called mini, not micro2. There are 2 mini fuse (low-profile mini fuse (4), mini fuse (3)) labeled in the above link.
https://www.viofo.com/465-large_defa...er-holder.webp
Thanks,
Old 01-02-21, 09:29 PM
PotOdds
PotOdds's Avatar
This YouTube was helpful.
Recommended using the 15A P/OUTLET NO.1 port.
Old 01-03-21, 06:12 AM
Quantum501
Quantum501's Avatar
https://www.clublexus.com/forums/rx-...sh-cam-10.html
Check out this thread (you link went to a deadspace) and specifically Post #138 forward between ejisfun and myself. I followed his post pretty much and found the most difficult part was fitting myself under the dash to get the fuse taps installed.
It is all outlined here.
Very happy with this dash cam.
Old 01-03-21, 06:40 AM
PotOdds
PotOdds's Avatar
Thanks Quantum. Appreciate the link.
As for the dead link, I've included the screen shot of the convo.
Old 04-02-21, 10:15 AM
WIZARD1325
WIZARD1325's Avatar
Default Trunk light fuse?
i was changing my bulbs in my trunk and the lights shut off. I checked the fuses under the seat and hood but i dont know if i missed somewhere
anybody know the location of the trunk light fuses? i used a volt meter and there is no power in the lines
2016 rx350
Old 04-02-21, 01:15 PM
WIZARD1325
WIZARD1325's Avatar
Fix it guess the lexus like to shut everything down for the battery. Do you have to manuel close the trunk and it resets.
Old 12-21-21, 09:29 AM
Hawaiimade
Hawaiimade's Avatar
Default Fuse tap
Originally Posted by dchar
Here you go...took off the cover when I installed a fuse tap for a dash cam.
which fuse did you use for acc?
Old 12-21-21, 01:33 PM
jcg0324
jcg0324's Avatar
2016 rx350
OMG now there are fuses under the seat? They seem to be everywhere anymore. Why can't they just put them all in one spot.
Old 12-21-21, 01:35 PM
Quantum501
Quantum501's Avatar
under the dash....and almost impossible to see and tap without being a yoga master.
Old 05-08-22, 12:14 AM
Lorn
Lorn's Avatar
Default Access Covered fuses
Hello,
Can someone please advise on how to access the fuses under the long black and red covers on the RX under the hood fuse box?
On the fuse lid it says that fuses like the alternator and the PBD are under there. I just can't seem to figure out how to get to them. The other fuses are easy, I can just use the fuse tool.
Thanks!
Old 11-21-22, 07:55 AM
RollingBlu
RollingBlu's Avatar
Default Where is the Fuse Panel?
I have a 2016 RX450h. The owners manual says there is a fuse panel under the drivers side dash. I have removed the plastic covers under the dash and the side kick panel and there’s no fuse panel. I even tried the passenger side, No fuse panel there either. Does this fuse panel even exist?
I know about the one under the hood. I'm trying to determine why the radio is dead.
Old 11-21-22, 08:47 AM
bamalam
bamalam's Avatar
It's there, and you don't have to remove the trim covers. Find the OBDII port on the driver's side. Go forward 3" and outboard about 3" and look straight up; the fuse panel faces downward and has a typical fuse box cover on it. Be aware, accessing the fuse panel is tortuous. A skinny contortionist will have the easiest time.
ravenuer (11-21-22)
Old 11-21-22, 10:46 AM
RollingBlu
RollingBlu's Avatar
Thank you bamalam. With your help I found it. WTH were they thinking hiding it at an almost unreachable location. It would have been nice if they had listed the fuses in the owners manual like most cars. The low contrast ink on the cover adds another touch of User abuse.
bamalam (11-21-22)
Quick Reply: Fuse Box Locations
