Fuse Box Locations
Hello All,
Are there more than the 2 fuse boxes shown in the owner's manual (one under the hood, one under driver's side)? The reason I ask is because I looked at the fuse diagrams for both and it seems like some are missing.
The fuse I'm mainly interested in is the fuse for the 12V socket located in the trunk. The fuse diagram from under the driver side box only has a fuse for "P/Outlet No1". I was assuming there'd be at least 3 (1 for each of the 12V sockets).
Can anyone shed any light on what's going on? Are the 12V sockets associated with some other fuse?
Thanks!
Thanks!
I believe the 12V sockets, all four, are all on the same circuit and fed only from one fuse and limited to 120W total. I could be wrong but the best way to find out is pull the said fuse and test the outlet for voltage.
Hi, I've looked through many threads, searched the forum, looked at the manual, googled the internet, but I'm still unable to locate the interior fuse box panel for my 2017 RX 350.
According to Pg. 607 of the owners manual, the fuse box cover should be below the coin tray to the left, near the OBD connector. However, all I see is a single piece of soft plastic with holes cut out for the OBD connector and vent openings. This piece of plastic is screwed in. Do I have to unscrew it to see the fuse box cover underneath? Has anyone had success finding it?
The following 7 users liked this post by SoCalRX:
cycotron69 (01-17-18),
elimmigran (01-12-18),
mcomer (01-17-18),
Oldfart (01-12-18),
PeeVee (11-22-22),
and 2 others liked this post.
The best way to access the fuse panel is to remove the black plastic shielding shrouding the steering column. There are three 10mm bolts at its front end holding it in place. From there you can drop the shielding down and get better access to the fuse box. The fuse cover can just be pulled down from one end (I pulled the end toward the fire wall) and it easily snapped out.
The following 4 users liked this post by dchar:
Hello All,
Thanks!
Thanks!
I have a 2016 RX350 and I am trying to install a VIOFO Dashcam A129PRO 4k and need to know which fuse I need to remove to be able to use the Buffered Parking Mode. Thanks
Idorablo (05-16-24)
A320pilot (02-14-22)
hi, Im installing a a119 v3 and need to know what to tap into for buffered parking mode. anyone ? thx...
