Transmission fluid change (merged threads)
Old 06-20-23 | 04:20 AM
  #166
Quantum501's Avatar
Quantum501
Originally Posted by itsokay
Link should still be up for all the videos, let me know if you're having issues downloading them. I think I uploaded the wrong one for coolant, it's linking to the GS. I'll look for the coolant video.
Brake release for rear:
https://www.dropbox.com/s/1k2serj6ph...0Mode.mp4?dl=0
thanks again.
I have the release video but was wondering if you have the actual brake job videos. He did separate front and rear brake videos but I never copied them. Again, not a big deal since I have done brakes many times.
The coolant is for the GS. Our gen RX has block drains that Viktor showed. Probably doing coolant soon, but again not a problem. Hope that he comes back again, but not looking good.
Old 07-09-23 | 02:31 PM
  #167
ckeller52's Avatar
ckeller52
6th Gear
Thanks for this. I'm on a series of three changes on my 2017 RX 350 and I went looking for Viktor G’s video and poof, gone. LOL I’ve been searching all afternoon for the Temperature range and the torque spec’s. So thank you for sharing this. Much appreciated.
Now if I could just find how to lower the trans temp quicker. LOL
The following 2 users liked this post by ckeller52:
itsokay (07-10-23), Quantum501 (07-10-23)
Old 07-10-23 | 06:50 AM
  #168
jollick's Avatar
jollick
Originally Posted by ckeller52
Thanks for this. I on a series of three changes on my 2017 RX 350 and I went looking for Viktor G’s video and poof, gone. LOL I’ve been searching all afternoon for the Temperature range and the torque spec’s. So thank you for sharing this. Much appreciated.
Viktor's new YouTube Channel https://www.youtube.com/@Viktor_G_Automotive
He will be uploading most if not all of his old videos over the next several weeks.
ckeller52 (07-10-23)
Old 07-11-23 | 06:18 PM
  #169
bamalam's Avatar
bamalam
Hey @Quantum501 , what diff oil do you use in your rear diff and transfer case, and where do you buy it? I went to my local Lexus/Toyota dealer today to get the Toyota oil that VictorG specifies, but they don't sell it. The parts guy told me they use bulk 75W-90 for service, not the Toyota 75W-85. According to him, Toyota specifies their own oil "or equivalent."
Old 07-12-23 | 04:44 AM
  #170
Quantum501's Avatar
Quantum501
I picked up the Toyota LT75W-85 at my local Toyota dealer. It was overpriced but they had it. Last time I went there I just asked what they could do with prices of parts/fluids, and he matched online prices that were at least 25% cheaper. Otherwise you can use Redline GL5 75W-85....or any other. Redline is like $20 quart and Toyota is at least double.
bamalam (07-12-23)
Old 07-12-23 | 09:34 AM
  #171
bamalam's Avatar
bamalam
Perfect. Thank you.
Old 07-12-23 | 02:37 PM
  #172
Quantum501's Avatar
Quantum501
Perfect. Thank you.
No problem.
What mileage are you at?
I did mine at 30k and it was very clean. My RX is at 63k and I will probably wait until it gets near 80 or 90k to do again.
Let us know how it looks when you are done.
Old 07-16-23 | 06:58 AM
  #173
bamalam's Avatar
bamalam
No problem.
I'm at 48K now. It will likely be 49K+ before I get to the work, and I will post once it's complete.
Quantum501 (07-16-23)
Old 07-16-23 | 10:22 AM
  #174
Quantum501's Avatar
Quantum501
Should be good and clean but a good time to do it.
Old 07-16-23 | 10:29 AM
  #175
GS4_Fiend's Avatar
GS4_Fiend
I plan to replace my ATF at every 30k miles and differential/transfer case initial drain at 20k miles.
ATF will be OE, differential/transfer case will be Redline 75W-85.
Old 07-16-23 | 11:09 AM
  #176
jcg0324's Avatar
jcg0324
I have not seen any negative comments about Redline products in fact, Amazon is showing a rating of 4.9 out of 5 stars for the 1 gallon jug of 75w85 gear oil. And it is readily available either from Advance Auto Parts or online. I think I will be using it next time.
Old 08-06-23 | 01:28 PM
  #177
bamalam's Avatar
bamalam
I changed the rear diff and transfer case fluids today on my 2020 RX350. Both fluids, at 50K miles, looked very good to my eye and there was minimal metallic sludge on both the drain plugs. I used Red Line GL-5 75W85. Interestingly, the local Lexus/Toyota dealer doesn't sell or use the Toyota GL-5 OEM oil. Their parts desk guy told me they use bulk 75W90 oil.
The error I made was not putting the RX on 4 jack stands. I'm thin, so thought just running it on some 2x lumber I had would be sufficient for me to do the work. It was for the rear diff; doing that job is easier than changing the oil on a vehicle whose oil is easy to change. The location of the transfer case fill plug, though, made the TC case harder than it should have been. VictorG's video made it look pretty easy, but he had the car on a lift. It was a real pain with the car raised only 1.5in/38mm. My torque wrench was too long, so I just had to get the fill plug "nice and snug" as VictorG said.
One last thing: the TC plugs are 24mm. That's pretty big. The only one I had was an impact socket, and it was too thick to fit on the fill plug. I had to have my wife buy a standard 24mm socket from a local auto parts store. I did not have to grind the chamfered lead-in off to get a good purchase on the plug.
Quantum501 (08-06-23)
Old 08-06-23 | 02:03 PM
  #178
Quantum501's Avatar
Quantum501
Looks good....very clean. I just picked up a bunch of the RedLine 75W85 for my wife's 4Runner (front and rear diff), and mine when I do it again.
Much easier up on jack stands. Tempted to keep the 4Runner on the ground but will see.
I bought a 24 socket that was very short and narrow that worked well on TC. Didn't even need extensions to replace.
Good job....should be good for another 50k+
bamalam (08-06-23)
Old 08-06-23 | 02:16 PM
  #179
GS4_Fiend's Avatar
GS4_Fiend
IIRC, TCCN recommends the transfer case and differential fluids to be replace at 30k miles interval.
The following 2 users liked this post by GS4_Fiend:
bamalam (08-06-23), jcg0324 (08-07-23)
Old 08-06-23 | 02:30 PM
  #180
dibl's Avatar
dibl
I changed the differential and the transfer case fluid on my 2018 at 50K miles. I rolled the car onto 2x10 lumber pieces on the garage floor and that was high enough for me. The rear differential was easy-peasy, the old fluid didn't look dirty and there was very little gray metal debris on the plug. I bought two 1 qt. bags of Amsoil 75W-90, one each for the differential and the TC.
The transfer case, however, pretty well kicked my a$$. A standard 24 mm socket was just too tall to fit the space, no matter how I wriggled and angled and tried u-joints. I could have ground down my socket on my grinder. I thought hard about it, and decided to just take the oil to my favorite Muffler Bros. shop and pay them to do it, and also to rotate the tires. My bill was $79 for both. They said the old fluid appeared to be in good shape when they drained it.
The following 4 users liked this post by dibl:
bamalam (08-06-23), jcg0324 (08-07-23), Quantum501 (08-07-23), ravenuer (08-06-23)
