Transmission fluid change (merged threads)
#226
Lifetime Fluids - Not exactly.
Lexus gives you a 70K / 6 year Powertrain Warranty.
That's your lifetime.
I do complete fluid changes every 5 years or 35K miles.
Coolant, Transmission Flush, Differential, Transfer Case.
Flush! Yes, if you change it every 30K, there is ZERO chance of it clogging.
Aisin Wagner Transmission Fluid. https://www.aisinaftermarket.jp/en/p...atf/index.html
Motul Diff and Transfer Case. https://shopmotul.com/automotive/gear-oil/
JeffKeryk (06-13-24)
#227
HPL green cc atf $60/gal. The dealer charged $90. Lexus dealer charges too much.
I also did the transfer case, rear differential oil and supplied the Mobil 1 Delvac 75w-90 with 4.6% Redline friction modifier (unnecessary and just had it around). My independent garage did it for $85.
#228
On my 21 RX8350 with 17K miles, I want to a drain/fill with either HPL green or Redline D6. Both are Toyota WS compatible. Replacing 4qts out of 7,2 qts,
The warranty runs out In March 2027. That is almost 3years away. I like to address the Toyota WS early and get it out of the way. I am even thinking going with HPL Green or Redline D6 (which are in the basement.
Has anyone used HPL ATF green or Redline D6 in a RX350 U881F transmission? Any issues? Any performance shifting changes?
I put in Redline D6 in my Toyota Venza V6 U661 transmission and it work great at 120k. Real smooth.
Therefore, there is zero chance of any clogging but the fluid is fully renewed.
If you do a drain and fill, I would stick with Toyota OEM fluid and not mix with aftermarket.
As a complete flush its fine but not as a partial.
Yes, it's WS fluid but... I wouldn't mix it.
ravenuer (06-16-24)
#229
Where did you buy Aisin Wagner Transmission Fluid?
#230
At 30K I do a full Transmission Flush.
https://bobistheoilguy.com/forums/th...2#post-6919208
#231
In the Toyota can or in bulk with Independent dealers.
A true flush is only possible with the needed equipment.
Around $5K in cost .
If you have 40K+ on that Transmission, I would stick with drain and fill.
By 60K, forget it. The fluid is very dirty and could clog.
I go 30K and have it flushed. Never an issue.
#232
Transmission fluid exchange?
2019 Lexus RX350 F-Sport
We took the vehicle in for its routine 40k mile service. Not much gets done here but I asked the dealer about doing a transmission fluid exchange since we drive mostly city, stop and go traffic.
He said Lexus doesn't recommend changing the fluid. He said they don't even have a way to do a fluid exchange. He said if it ain't broke don't fix it but that's not how I work. 👍🏻
What's your opinion on this?
Whats the power train warranty on these suckers?
#233
The bottom line is that if you plan to keep the vehicle beyond say 100,000 miles, then a one time drain and fill at each 50 - 60,000 mile intervals is probably a good idea.
If you turn your car over b/f 100,000 miles then you will never have a problem (but the next guy might).
I questioned the lifetime fluid with my wife's 4Runner when I noticed that it had never been done by 140,000 miles (she handled the maintenance). By around 200,000 miles it started to slip and Toyota said that it was beyond the warranty.
I had an Acura that I did transmission fluid drain and fill at 50k intervals and sold the car at 305,000 and it ran perfectly.
Check out Viktor and Care Car Nut video links above.
If you are at all DIY then the job is pretty easy. Dealerships can and do the service b/c it is listed as a maintenance service item if you tow....so if your shop won't then take it to a Toyota dealership...or just tell them that you tow. BTW, use OEM fluid.
ravenuer (07-11-24)
#234
If you decide to change the fluid, just don't go to the dealer who doesn't know how to do it.
Fully agree with Quantum501.
#235
Takes out over 95% of the old and replaces it with the exact same amount. No guesswork.
Ask them to use this Toyota OEM Fluid: Aisin Wagner Transmission Fluid. https://www.aisinaftermarket.jp/en/p...atf/index.htm
That's Toyota OEM fluid and it's a Aisin Transmission.
I flush mine every 30K with little to no chance of it clogging.
30-40K should be a safe range for a Flush.
Beyond that, and I would do a drain/fill with ONLY Toyota/Aisin fluid.
#236
Looking for some quick advice on tranmission fluid drain/fill
I just completed a drain/fill of my 2020 RX350 (63,000 miles) using the Viktor G procedure and think I have a problem. I had the vehicle as level as possible and the final level setting was done in the 100-104 range using the OBD Fusion software and a Vgate OBDII device. I'm not convinced the fluid level is set right, though, as I think it has about 1/4 qt less in it now than it did before the procedure. Here's my math and procedure:
What do guys think? Am I ok? If it was your vehicle what you do now?
- Initial drain: ~3.15 qt measured in a 5qt measuring bucket. I didn't spill more than a few drops outside the bucket.
- Filled with ~3.78qt of Toyota ATF WS fluid.
- Started the vehicle and connected the Fusion software. A/T fluid temp was already at 98F (hot here today). I cycled through Reverse/Neutral/Drive/Park (loud clunk when shifting into Drive - not sure what that was.)
- I opened the drain tube plug and it drained ~ .9qt before starting to sputter a little and replaced the drain tube plug.
#237
I think I recall that you bought the car new, so we are assuming that the level was set correctly at the factory. If it was purchased used, you have no idea if the level was correct to begin with.
I would assume that there is some variation in your measurements (using a bucket vs graduated cylinder), as well as what constitutes a "trickle". CCN video shows him closing up drain with slightly more flow than Viktor. So I think that you have some wiggle room and don't need to get the exact volume down to the oz. Also, the temp range will have some variability, so exchanging on the low end of the temp range will have a different level from the high range. I would think that if you did the exchange in the proper range and have a close volume before and after, that you are fine. I don't recall the total volume of ATF in the RX, but remember that you are only exchanging a small percentage overall.
I would be comfortable with your numbers if it were my car, but you can always repeat if it is going to drive you crazy. Good luck.
#238
I considered redoing the procedure, as I have 4 more quarts of AT fluid on hand. However, 1) I don't know that I'd get a different result and 2) I don't know that sequential drain/fills are a good idea. Taking your thoughts into consideration, I decided to split the difference and added ~ 4oz into the fill hole and not redo the level check. I'm going to button it up and take it for a test drive now. Hopefully my biggest problem is OCD. Thanks again for your thoughts.
Quantum501 (07-20-24)
#240
Change your tranny fluid!
I was talking to my dealership service engineer (in Japan) the other day (had a 6 months checkup), and he said that even though Lexus recommends 15000km, he personally thinks 10000km is a better idea, since at 15000km the oil gets noticeably dirty. So I'll go with 10000km interval. Better spend money on oil than on fixing the engine
In other news, it looks like ATF (transmission fluid) doesn't need any maintenance AT ALL for 4RX and basically any Toyota cars build in last 3-4 years (speaking of Japan though, so ymmv)
