Bluetooth Phone Audio Issue
I have a 2016 RX350 and recently am experiencing low volume when on a phone call. I disconnected and reconnected my iPhone 6 and have made sure the volume for phone calls was at the max setting. The person can hear me, although they say I sound as if I am in a tunnel. I cannot hear my caller...sounds like volume is at the minimum. The radio. CD and Bluetooth audio for my music is otherwise fine.
Let dealer check the microphone. My service adviser said it's a common problem.
Some 4RX have sunroof leaking problem. The water will accumulate and eventually drip out from the microphone hole. Maybe it is related to water damage.
LizF (03-21-18)
Thanks for answering .I have had the car for a year and 5 months and have opened the sunroof once. I am assuming then that the phone speaker is separate from the radio speaker? My radio and cd sound is unaffected.
The audio you hear will have nothing to do with the mic. Are you increasing the volume on your phone, while in a call? There are other ways to do this, but it's just the easiest to do without going through the menus.
LizF (03-24-18)
I find that the bluetooth reception to my Samsung Note 8 for playback on the car's speaker is kinda low also. Meaning I have to crank up the car's volume over 45 to have the same level as the radio (25). This is with Youtube music. My car is 2018.
Anyway, OP, you can test your problem with a different phone to determine where the phone lies. My last phone Iphone 6s plus had the same problem where I could not hear the listener through the earpiece. The speaker phone on the iphone wasn't much better. But this was all about the iphone.
Mike728, I will try that on my phone. I have the volume in the car's audio for phone calls at the max. I think that I will test it on another phone...thanks, that's a good idea. I will first try to increase the volume on my phone while on a call
Mike728. While connected on Bluetooth call, I increased the volume on my phone!!! That was it. The Bluetooth volume on the phone was turned down. Such an easy fix! Thank you so much!!
Were you able to find a solution?? I've tried all the settings I can think of and find on the phone and car...
RE: Bluetooth phone IPhone 6SE
2016 RX350: the quality of the microphone is bad....any suggestions? Can it be replaced by a store like Best Buy?
ummm, no. best buy can not replace the microphone. What is it doing that is bad ??
be aware of its location, so talking straight ahead vs at the rear view mirror, although either should work fine.
if you have a small sunroof, it could have had water damage ?? any staining or anything around it?? a few had leaking issues, but no report on their microphones,
are there adjustments, on the main screen when on the phone, usually there is.
Hi - I am having a road noise/speakerphone issue. It's been to the dealer several times and they have replaced the speakerphone and bluetooth module. Dealer claims it's not a common issue. I have a 2017. I will be trading since it sounds horrible. Do you have a 2018? Is it any better? Any tips would be appreciated. I previously owned a 2010 and it sounded better.
