Vibration at speeds over 80 mph
Old 12-28-18, 07:45 AM
  #31
javapro
javapro's Avatar
Originally Posted by ut2sua
I have the 20" Ecopia's on my RX4 and they are quiet at high speed.
What about a slight vibration felt through the gas pedal when you go above 80 mph for a few minutes?
Old 07-17-19, 12:18 PM
  #32
Oldernu
Oldernu's Avatar
Default Autotech13 Reply
This is a safety control issue. As other posters stated, the TSB's apply to vehicles listed on the bulletin. These are well documented problems which Lexus has acknowledged and addressed in technical bulletins applicable to vehicles described there. If your car vin is listed and the franchise manager doesn't instruct the service manager to install the remedies listed in the TSB's, let him know you will escalate to corporate--and if the vehicle is involved in an accident, every person in the dealership who failed to comply with the Lexus TSB instructions will be named as defendants in the lawsuit.
Old 07-22-19, 10:52 AM
  #33
Oldernu
Oldernu's Avatar
Default Ineffective Reboots
The dealer should be able to read the ECU to determine if the reboots were dated. The code on the ECU should be compared with the TSB code--wouldn't be the first time a service tech input a wrong number and didn't check his work. The battery must be disconnected for minimum 30 minutes, according to one tsb. If procedure isn't followed, problems will occur. If it is verified that the updates were done correctly, it's possible that a defective computer chip/components are causing the problem. Get the service manager to ride shotgun while you drive and demonstrate the issue.
Old 08-02-19, 05:24 AM
  #34
ravenuer
ravenuer's Avatar
Originally Posted by KevMaster
Thanks to this thread. I convinced the dealer to do the TSB update and the RX drives so much better to the point I'm getting a 3mpg improvement
Wrong thread. This one is about tire vibrations.
Old 08-02-19, 11:50 AM
  #35
KevMaster
KevMaster's Avatar
Dang it! Sorry. Moved the post
Old 09-06-19, 09:38 AM
  #36
Googs
Googs's Avatar
I am surprised there isn't a class action yet!
Old 09-07-19, 08:35 PM
  #37
xxx350L
xxx350L's Avatar
Has the dealer used “chassis ears” yet?
Old 09-08-19, 11:35 AM
  #38
yongosu
yongosu's Avatar
I have 2016 RX350 AWD. at 50000 miles I switched from Michelin to Bridgestone and it starts vibration over 80MPH. I read some reviews online for the Bridgestone tire, a lot of bad reviews about vibration.
Old 09-08-19, 03:10 PM
  #39
mikemu30
mikemu30's Avatar
Received 2,516 Likes on 1,796 Posts
New tires - make sure they are properly balanced and not out of round.
Old 09-08-19, 10:14 PM
  #40
ljeffyoung
ljeffyoung's Avatar
Dealer did the 4 wheel alignment for my vehicle when switched the new tire. Is that the problem? Dealer didn’t do the wheel balance.
Old 09-11-19, 03:27 AM
  #41
JSracer
JSracer's Avatar
the definitely balanced them when installed, now rechecking or road force might be worth looking into
alignments won't cause a vibration
chassis ears, like for chasing noises, with the clip on leads ?? for a vibration ?? or the hi tech that reads frequency, that could work also. First-order tire/wheel vibrations usually produce a vibration frequency of 10-20 Hz
Old 12-13-19, 04:08 AM
  #42
dibl
dibl's Avatar
My 2018 F-Sport came new with Bridgestones. I have been pleased -- I never used Bridgestones before, but at 21,000 miles they are holding up well with zero problems.
Old 12-13-19, 09:29 AM
  #43
ut2sua
ut2sua's Avatar
Mine came with the Bridgestone tires, and there has not been vibration issue at high speed. Super quite tires too. Your issue could be with balancing...
Good luck
Old 12-13-20, 07:14 AM
  #44
Les7311
Les7311's Avatar
Will surely check in this.
reference post 160 for the TSB
thanks.
Old 05-04-24, 11:39 AM
  #45
RCosler1
1st Gear
RCosler1's Avatar
Default Out of trundle tiresd
Originally Posted by jim256
Out of round is a condition that may have happened when the tire was made, so they should check for that as well. The old way to test it was jack the wheel up, put a coke bottle next to it touching the tread, rotate the tire and see if the bottle moves or falls over. I'm sure they have better ways now!
An out of round tire is not as uncommon as might be thought. Have had this issue and was told by a Firestone service person to buyi Michelin' "They're the round ones"!
ravenuer (05-04-24)
prankster
10-24-21 12:18 PM
mistwang
Hybrid Technology
15
12-19-17 02:42 PM
TWillz
LX - 3rd Gen (2008-2021)
06-02-17 08:43 AM
SyedH
RX - 3rd Gen (2010-2015)
09-26-16 07:27 AM
E168
08-06-08 01:24 PM
Quick Reply: Vibration at speeds over 80 mph
