Bi LED headlights vs Bi-LED Adaptive in a 2018 RX
From what I can see, Bi LED headlights are standard on the 2018 RX. Bi LED Adaptive headlights are an option as well as the triple beam LED headlights. What is the difference between Bi LED And Adaptive Bi_LED
Click on the "Headlight" link on the left side of the following web page to see the information: http://www.iihs.org/iihs/ratings/veh.../rx-4-door-suv
Only the optional LED Adaptive headlights get an "Acceptable" rating from the IIHS. Both the standard LED and optional triple beam LED headlights are rated "Marginal". Relatively few headlight systems have earned the IIHS highest "Good" rating.
Corolla has Bi-LED standard, and Multi-LED available. Not HID.
If "only multi-LED systems are luxury features", then what does that make the entry level sub-$25K Honda accord with its 20 LED headlight system? Does it make it more than three times more luxurious than an RX with the triple beam system? Of course not.
There is certainly nothing wrong with you valuing looks over performance and safety. That is an individual choice. Others may choose otherwise.
IIHS headlight ratings are based on extensive scientific testing and are not in any way arbitrary.
The line between luxury, premium, and base are becoming more and more blurred. Sedans are having a harder time selling so these typically optional features are getting pushed down to base models. The number of LEDs is not the metric for luxury (lol 20 LEDs?). It's that you typically see only luxury cars having multi-LED systems. But as time passes, luxury features become common features. The accord is a good example of that and I'm sure when more cars switch to LEDs it will no longer be a luxury item.
Of course, to each their own. I never meant to imply otherwise. Just because the accord has LED headlamps doesn't mean it looks good.
The number of LEDs is insignificant and is not what defines a luxury feature. LEDs are a reinvention of the lightbulb per se, which is why you're seeing it being used across the board. It's new but mainstream and relatively cheap. It's the modern day filament.
It's the way the LED technology is used such as in the video below where the cars are able to keep high-beams on at all times while shielding other cars and people around from being blinded by using individual LEDs. The vehicle is able to specifically choose what areas of the road to light up and which should not be illuminated such as vehicles in front or around, highly reflective signs, etc. This is a luxury feature, currently at least.
By arbitrary, I mean they assign a marginal/good rating instead of giving us useful metrics. What defines marginal? Good? How much light is outputted from type of system? What is their definition of useful illumination distance? When I tried these different systems they all looked the same to me.
I hope the IIHS continues to test headlights and crash test vehicles so that I don't have to do my own seat-of-the-pants evaluations and simply hope for the best.
Vroomin350
02-01-12 04:24 PM
