Topping of Gas - Causing Knocking
Does anyone top off their gas (adding an additional 50 cents to 1 dollars) to your tank?
I have had this knocking in the rear after the last 2 fill ups but the issue has been happening for over a year. I brought it in to Lexus awhile back but we were not able to reproduce the issue. I finally noticed that it only happens with a full tank of gas. I only get gas every 3 or 4 weeks so I was wondering if anyone else has this knocking issue. It sounds like someone is taking a metal bar and hitting the gas tank. Next time I will not top off to see if the issue occurs.
AdamDob (10-02-21)
Temp doesn't matter in this case. It happens year around. The knocking is def in the back. I got under the suv and can clearly hear the knocking around the gas tank.
I do not know where evaporator canister is located in RX but it is possible when you top off gas can be sucked into the canister. That is why topping off is not recommended.
TeKKieNYC (08-07-18)
+1 on adding beyond the cutoff, but there have been some reports, along with my experience, that when full there is a slight knock from the tank on a rough road, goes away quickly with use. In the old days it would be a float, no idea now.
Why top off? What's the benefit? You are filling beyond capacity, gas needs the room to expand, plus you may be flooding your charcoal vapor canister.
Im in NJ one of the few states that still prohibits self serve. First thing I tell them when I pull up to the pump - DO NOT TOP OFF.
Old school people like to top off to the nearest dollar or even to the nearest 1/4,1/2,3/4 of a dollar so they dont need to get change or something. I usually dont do it anymore because i use credit card and a few times I've experienced it over flowing out when it did it on my old mazda
ravenuer (08-08-18)
Topping off is a bad idea with modern cars. Going to the next nickel or dime is probably ok, but that's it.
I'd say most people pay by credit/debit today, so just let the pump stop itself.
Car stalled
Ok I was a habitual topper. Had the car die twice on me after filling up and topping about 2 gallons. After top off went to drive through when leaving car stalled and died. Took about 5 minuets to restart. Soooo I don’t top off any more.
