Inside rear view mirror a bit loose
My inside rear view mirror became slightly loose and wobbles a bit. I see it can be tightened with a torx screwdriver but I can't reach in there with the tool due to the plastic cover that is attached to the windshield (I assume) that is obstructing access to the torx screw holding the mirror.
Has anyone else noticed that their inside rear view mirror is loose? Also, does anyone know how to remove the plastic cover that the inside rear view mirror stem goes thru? I have attached a photo of the plastic cover.
Thank you!
Thank you!
acotugno (09-29-18)
