Aftermarket carplay on 2017 RX350
#1501
Hi, I am able to adjust the AUX volume on the Lexus system with no problem. In the Road Top carplay device audio setting, I am able to adjust the master volume, notification volume, music volume, and speech volume individually. I did some test and the unit is using the Music Volume for both Spotify and the iHeartRadio app. I was able to find a setting in Spotify to use "quiet" as the normalization setting to make it a little less loud, but there is no such setting for the iHeartRadio app and it is still not as loud. I hope someone have a solution.
maraynman (03-28-23)
#1504
Dang, this is not encouraging! These things cost a lot of money to be this buggy & riddled with problems.
#1506
To get the good sound on GROM VLine VL2 or VLite VT2, you need to go to the Factory UI that corresponds to the stereo mode, taken by VLine / VLite. Once there, please adjust the sound settings such as bass, treble, etc. Check here how to:
#1507
Is that VLine VL2 or VLite VT2 system that you installed?
https://youtu.be/5CaAZH3mmqI
This is my 4th Grom for four different Lexus models. This one by far, is not the same experience.. The audio is not crisp, sounds like it's playing non-HD radio, if you will..
#1508
I just installed my VT2 this week and it sounds great. ML audio. I have only used AA as I don't have an Iphone I can't compare Carplay. I am only using it wired. It does work wireless but the sound and operation is better wired, although it doesn't sound muffled as you describe wireless. I tired the Roadtop unit for a few days and was having issues so I pulled it and returned it for the GROM as I had previous experience with it in my van.
gromaudio (03-01-23)
#1509
Wanted to share my experience with the GROM product.
I had originally installed the RoadTop unit and had some issues. Due to the amount of time it took interacting with customer service overseas and the time difference I decided to pull it and send back for a refund since I was coming up on my return window. I went with the GROM VLine 2 when the group buy came up. I was familiar with this unit as it is the same one we have in our van.
Upon installing the VLine 2 it was defective out of the box. The screen had issues while in VLine mode so it was unusable. This is where GROM stands out from the rest (IMO) with having state side service (Dallas TX). I opened a support ticket and was assisted right away and asked to provide a video to show them the problem. Within a day they determined there was a hardware issue with the unit and it would need servicing/replacement. I inquired since I needed to send it back for a serving/replacement could I just return it for the VLite because it had become available. That was really the only features I wanted as I don’t use the other features of the VLine in the van. They said no problem. I purchased the new VLite 2 and swapped the units when it arrived. It is working perfectly and sent the old one back. Only real negative experience was they didn’t pay for the return shipping on their defective out of box product. I had to pay to send it back. I feel they should have covered the cost of that since it didn’t work when I received it.
Pros:
Some pics of the install.
Cut a hole below where the glove box slides in and out so the wires would not bind.
hole in glove box feeding wires through
Mounted to top of glove box with velcro. Ran USB from radio to VLite to retain factory USB from center console
Pros:
- Android Auto/Apple Car Play
- All factory functions retained.
- Wired or Wireless functions
- Modernizes your car
- US based customer support
- Not Cheap
- The VLite does not come with any extras (cables, USB, GPS, etc)
The following 4 users liked this post by exploreco:
#1511
Are there any other units customers in this thread have had experience with besides Grom and RoadTop? Trying to find some intel on all the available units out there. Thank you to the Grom rep for the info from before and I found a Road top youtube review as well
. The local California pro audio installation shops want to install ZZ-2 https://zz-2.com/products/it-lex17-w...u&_ss=e&_v=1.0, and I found a BeatSonic link online as well
, and a local pro audio solo guy pointed me to a Chinese Honfox brand https://www.ebay.com/itm/274398254394. And curious if there are any other audio sponsors in this thread besides Grom, thank you!
#1512
Pros:
Pros:
- Not Cheap
#1513
My experience with Grom VT2
So here’s my experience with the Grom VT2 I installed 2 days ago. Installation was easy and straightforward and tools couple hours.
The sound is working fine for me and clear. You will not be able to use the car Bluetooth for making calls while using CarPlay as it will take you back to the Lexus system and won’t let you go back until you hang up the call. I’m order to make calls using CarPlay you will need to to remove your phone from car Bluetooth so it routes to CarPlay.
I thought the Grom was supposed to take you back to CarPlay when changing from reverse to drive but that’s not the case for me. It does take you back when changing climate.
It takes a while for the phone to connect to CarPlay when I start the car and sometimes the gps unit that came white doesn’t seem to be working as maps won’t update on CarPlay unless location services is always on or the app is open on the phone but than this defeats the purpose of paying for that gps unit and drains your phone faster.
sometimes everything works flawlessly and sometimes everything goes wrong as now I’m having an issue where I get kicked out of CarPlay and goes back to Lexus system and when I go back to CarPlay nothing works such as sound and buttons and this whole experience is starting to get frustrating.
it’s been a mixed experience so far and I’m still in contact with support to figure out the issue before returning.
The following 2 users liked this post by landij:
Bewill (06-16-23),
lighthurst (02-28-23)
#1514
The following 2 users liked this post by exploreco:
gadgetman1 (02-28-23),
#1515
See my replies in red below
I thought the Grom was supposed to take you back to CarPlay when changing from reverse to drive but that’s not the case for me. It does take you back when changing climate. It should take you back to the system. Mine has done so when coming out of reverse but I am also using AA not CarPlay.
It takes a while for the phone to connect to CarPlay when I start the car and sometimes the gps unit that came white doesn’t seem to be working as maps won’t update on CarPlay unless location services is always on or the app is open on the phone but than this defeats the purpose of paying for that gps unit and drains your phone faster. I had experienced this too with wireless AA as well. I decided to just do wired because the connections and sound quality is better and the battery drain so heavy that I was finding myself plunging the phone in anyways to charge. Wired it seems to connect up fairly quickly. They have a video about adding their GPS antenna which is supposed to help with battery drain but that antenna only comes with VL2 and not the VT2.
sometimes everything works flawlessly and sometimes everything goes wrong as now I’m having an issue where I get kicked out of CarPlay and goes back to Lexus system and when I go back to CarPlay nothing works such as sound and buttons and this whole experience is starting to get frustrating. I have had some issues where AA just locks up. If I am listening to Pandora it will just stop and the google maps will just stop. I will need to unplug and re connect and it fixes it.
it’s been a mixed experience so far and I’m still in contact with support to figure out the issue before returning. Hope you are able to work through you issues. I can say from this being my 2nd unit the process isn't perfect and may never be but it is so nice to have the modern conveniences. Good luck.
