Aftermarket carplay on 2017 RX350
Old 03-09-19, 06:37 PM
  #196
DOUGLis350
DOUGLis350's Avatar
I tried to read this thread as my wife wants a 2018 RX350L but it doesn't have navigation. Will this work with the 8" non-navigation screen?
Also, any major issues with install and sound quality?
Old 03-10-19, 05:02 PM
  #197
b1gpapa
b1gpapa's Avatar
This works in a 2019 rx450h base? Says the display is 8 inches on the dealers site.
Old 03-11-19, 07:59 AM
  #198
shadowmite
shadowmite's Avatar
The seller asks you for your config or a pic from your car to align the device to your screen size etc. Should work fine on a 8" screen also; albeit with a smaller display. A few pages back someone posted another device which would allow you to upgrade the smaller 8" to a 12.3" but you'd loose the OEM system going that route...
Old 03-12-19, 11:30 AM
  #199
llcw79
llcw79's Avatar
Installed it over the weekends, and works great(there're few glitches but can live with it)
Thx to @qvtruong for starting this thread and sharing valuable information.
Took me about 2hrs, installation itself was not that bad.
The worst part is putting everything into stereo bay.
It's big enough to put everything in but wasn't simple task.
And be very careful when you remove/install screws which hold the stereo system.
I dropped one, could not rescue it, so had to stop by home depot....
Ordered on 2/20 and received on 3/9.
Seller is very responsive and supportive.
Bottom line is
this box is worth ~$600 and 3hrs of my free time.
Old 03-12-19, 09:25 PM
  #200
lexnewbi
lexnewbi's Avatar
Would you mind sharing what are the glitches?
Old 03-13-19, 06:23 AM
  #201
llcw79
llcw79's Avatar
Sure,
as I said, it's not major..
1. when car is starting i hear some static sounds coming from car speaker. Maybe i connected car's speaker to the box thru AUX.
I am trying to resolve this but no luck yet.
2. Sometimes, when carplay is on and change the gear shift(P to D) then screen goes black.
Press the back button then it comes to normal carplay screen.
If I found other issues or glitches, I will post it.
lexnewbi (03-13-19)
Old 03-15-19, 08:34 AM
  #202
decngb
decngb's Avatar
Mine showed up yesterday after ordering on 2/25, or about an 18 day wait. I'll be reviewing the install videos and starting the work later today.
Old 03-15-19, 02:18 PM
  #203
Onion
Onion's Avatar
Ordered on 23rd, arrived today. Took a few hours to install but wasn't too bad. Want to add that make sure you use a 10mm socket, imperial ones won't work. I lost my 3/8 socket, it's somewhere down there. Thank God it didn't create rattle or anything. When you are removing the screen, note that the cover comes off, and then there is a bolt at the back where you need to loosen.
Apple carplay works perfect, however, Android auto is stretched. It seems like a Android problem as there are many complaints on the forum.
Currently I have my phone connect to Bluetooth on car, then car set to AUX. In this case, hang up pick up button still works and other sound will go through wire.
My only complaint would be that Android auto stretched screen and the Charing speed. On my phone it shows 8 hours till fully charged. And as I'm writing this, I just lost 1% of my battery.
Pictures are system Waze vs Android auto waze
mcalr3 (12-12-20)
Old 03-15-19, 08:51 PM
  #204
decngb
decngb's Avatar
Originally Posted by Waleedg
Quick update:
after contacting few sales specialists and getting no where with then.... one of them advised me to get another screen and try the unit with it to fix the resolution... that wasn’t by any means possible to me...
Then I had been contacted by someone called David, and I think he is the sales manager...
He gave me an update file and instructions to put it in a USB and hook it to the USB1 port to update the unit...
I seem to be having the exact same problem as Waleedg. Press/hold the hang up button makes the screen flash and then freezes on the Lexus screen. Press/hold again, and it switches back to functioning Lexus screen. I am trying to reach out to Mr. Cosmo to get this resolved, but I'll take any pointers here.
Old 03-17-19, 01:14 PM
  #205
shadowmite
shadowmite's Avatar
I got mine yesterday and now need to plan a day to install. Likely next saturday. I'd really like to run the usb cables and iphone cable into the center console storage area. I'm thinking a couple USB extensions to get them there...
Old 03-17-19, 01:36 PM
  #206
qvtruong
qvtruong's Avatar
I redo my cables to run it through the center console. Behind the cigarette lighter, you can get the cable from behind the headunit down the center console. See my pictures. It needs some patient tho.
Old 03-18-19, 05:46 AM
  #207
Gottspd
Gottspd's Avatar
please let us know what you find out!
why not just use the Apple carplay phone app and skip BT? What did you have to connect to use the aux input?
Old 03-18-19, 06:17 AM
  #208
Onion
Onion's Avatar
i have an Android, so not sure about apple car play. If I connect my phone to the head unit via Bluetooth and skip BT it looks like I will have to use the next track/last track buttons as pickup/hangup. If I don't use BT then phone calls will go through my phone's speaker.
Old 03-18-19, 06:26 AM
  #209
Gottspd
Gottspd's Avatar
Can you have carplay on the left 2/3 of the screen (of a LHD vehicle) and leave the right 1/3 to show, for example, the hybrid energy monitor?
Old 03-18-19, 06:31 AM
  #210
Gottspd
Gottspd's Avatar
so you can still use Apple carplay with an android with this device? That’s interesting. Does that mean that this Apple carplay doesn’t work like it does in a car that natively has it, ie, usually it looks at the apps on the phone and uses them to know what apps to display on the carplay screen?
Quick Reply: Aftermarket carplay on 2017 RX350
