Aftermarket carplay on 2017 RX350
#258
None of the RCA cables are used.
The CAM pwr cable as well is not needed.
You just need the big power cable, LVDS cable, USB ( if car play) , white screen cable (short cable with 2 wide white ends) and GPS cable ( if you wanted to connect GPS)
#261
Hi. Good news. Got the device. However when I press the aux button nothing happens and when I press the hang up button it beeps, flashes purple and then goes right back to the main screen. And the main screen is flickering purple sometimes. Any thoughts?
also. This wire should be plugged in right?
#262
Thats the screen wire. It needs to be connected behind the screen.
#264
The main power cable has 5 ends that need connected. Look at post 172.
Power cable is connected to ports numbered 1 and 5.
5 is the second port to the right of big wide power cable ( marked 1)
#266
Awesome. Phew!!
i have no such TV and no power outlet to
take my car to.
I’m soo glad the display issue did not happen with me- like you and one other member in the forum.
Enjoy. I will post some of my findings once I collate them all.
take my car to.
#268
For those that have installed the device, do you find that the Lexus mouse is a bit wandery and has a bit of a mind of its own? If I move the cursor, often it’ll continue moving long after I’ve stopped moving it.
#269
I feel it’s a little stiff. The movement is not as smooth.
