Aftermarket carplay on 2017 RX350
Old 04-13-19, 11:58 AM
  #331
Gottspd
Gottspd's Avatar
Originally Posted by c3uo
Is it possible that the passenger disply turned off as you went from dual mode climate to single? I think that the passenger side temp display shuts off in single.
you are close! It wasn’t that but in the 16’s, I learned today that there is a feature called “S-Flow” which can turn off the pass side. The ‘19 loaner we have doesn’t have that. Maybe it’s an option. Anyway, I didn’t discover that until I had fully removed the android box. Then once I realized it wasn’t the box, I reinstalled it with dip3 down. So far things are working as they were and there’s one pleasant change... before I wasn’t able to see any visual volume control when in carplay and now there is! Cool. Not sure why but I’m pleased that it’s working.
Old 04-13-19, 01:39 PM
  #332
hnws
hnws's Avatar
A very basic and silly question, what's the screwdriver and its header do you guys use? I bought something from Home Depot, but it seems to me 7/16 is too large and 3/8 is too small???
Would anyone please kindly paste a link for what you bought to disassemble those two screws? Thanks.
Old 04-13-19, 01:41 PM
  #333
Gottspd
Gottspd's Avatar
Japanese vehicle = usually metric so you were close in size but it’s a 10mm.
All 3 bolts and the 2 nuts are all 10mm conveniently.
hnws (04-13-19)
Old 04-13-19, 01:58 PM
  #334
hnws
hnws's Avatar
Thanks. Just ordered one set including 10mm from amazon.
whiteghost (08-21-19)
Old 04-13-19, 02:01 PM
  #335
Gottspd
Gottspd's Avatar
Magnetic ones? Highly recommend that.
Old 04-13-19, 02:09 PM
  #336
hnws
hnws's Avatar
Yeah definitely. (I just dropped one screwdriver header inside during trial and errors...)
Old 04-14-19, 04:14 AM
  #337
Bearcat
Bearcat's Avatar
In order to use AUX with the box does BT need to be disconnected from the box?
Old 04-14-19, 05:10 AM
  #338
Gottspd
Gottspd's Avatar
Apparently later years have S-Flow via the climate screen.
Anyway, still having some issues with the box. Is there a way to force it such that the box only only can connect via BT and not the box from an audio perspective? Seems like that there could be a phone solution there too. Make it so it the box isn’t an audio output option. Any thoughts?
Old 04-14-19, 09:40 AM
  #339
Bearcat
Bearcat's Avatar
To everyone having trouble with AUX, make sure you delete BT pairing with box/RX/phone. It’ll work great then. Dumb mistake on my part.
Old 04-14-19, 03:31 PM
  #340
KBBK
KBBK's Avatar
Originally Posted by jwong77
Can anyone share an image of what the base non nav screen might look like with this installed?
johnmacm (05-07-19)
Old 04-14-19, 05:56 PM
  #341
Gottspd
Gottspd's Avatar
How’s the call quality for you?
Old 04-14-19, 06:00 PM
  #342
qvtruong
qvtruong's Avatar
OMG...you just saved us all. Cosmo, David and I spent hours trying to see why the AUX didn’t work on mine. We forgot that the bluetooth was still connecting. We had no idea what caused it...until now lol
Old 04-15-19, 10:57 AM
  #343
Bearcat
Bearcat's Avatar
Glad I could help.
Old 04-16-19, 07:49 AM
  #344
KBBK
KBBK's Avatar
Can someone show/explain how to go about deleting the BT box? I have the 8 inch non-Navi setup and my settings & options screens look nothing like those qvtruong has shared.
Thanks
Old 04-20-19, 03:45 PM
  #345
jjj666
jjj666's Avatar
Thanks to qvtruong and Bearcat! I have the unit installed on 16 model and use aux. But seems I have a problem. If I put the display to android mode by pressing the hang up for 3 seconds when in parking, then I shift to reverse, the display shows the reverse camera, but then if I switch to driving mode after that, the display go back to lexus display instead the android display, I have to press the hang up for 3 seconds again. Is this normal? Can I have the android be displayed after reverse? Thanks!
Quick Reply: Aftermarket carplay on 2017 RX350
