Aftermarket carplay on 2017 RX350
Old 06-05-19, 01:11 PM
  #496
joeguan3rx
joeguan3rx's Avatar
Originally Posted by Bearcat
I wish I was there to help you. I can get it done in 10 minutes now.
you guys have been great on the forum here. i am only brave enough to do this kind of mod on my car for the first time bcoz of great community support. I drove my last rx for 10 years and i didn't even change the cabin filter once and paid too much money for the dealer for very little simple things.
Old 06-05-19, 08:13 PM
  #497
birming
8th Gear
birming's Avatar
Originally Posted by Gottspd
A soft reset on your phone. I don’t think you need to do a soft reset on the android box, but it couldn’t hurt. To reset the android box, press the Mode and track up buttons on your steering wheel at the same time.
I did a factory reset and reinstall Autoplay application last version.
But, still not working.
Even when I just plugged the Galaxy s10e with no dongle, Android Auto is not starting.
Anybody can help me?
Old 06-05-19, 08:17 PM
  #498
joeguan3rx
joeguan3rx's Avatar
Try to get in touch with Cosmo in wechat is the best way to go.
Old 06-06-19, 05:27 AM
  #499
emhriv
emhriv's Avatar
Default Quiet phone calls
Installed the box a couple of weeks ago. Running into quiet phone calls while using CarPlay plugged into the dongle.
Sound of streamed songs from Apple Music or TuneIn radio is normal. Then I make or receive a call, the sound is very very quiet. I have to crank up the volume quite a bit to hear. The other side hears me ok.
The phone is not connected via Bluetooth to neither the car nor the box.
Any ideas?
Old 06-06-19, 10:45 AM
  #500
hjk
hjk's Avatar
Question Installation in 3rd Gen RX350 (2015)?
Hi all - read all 500+ posts in this forum, some a few times! Long time 05 ES330 original owner, and last week I traded up to a perfect CPO 2015 RX330! CarPlay was on my shopping list, but this thread convinced me there were good aftermarket solutions.
Has anyone with a 3rd Gen RX installed this unit? I see teardowns on YouTube for 4th Gen, but not having a lot of experience in this area, I'm intimidated.
Is there any wisdom that anyone has to share?
Old 06-06-19, 01:10 PM
  #501
joeguan3rx
joeguan3rx's Avatar
looks like he make the same android kit for the 3rd rx https://www.aliexpress.com/item/Andr...835355479.html the connection hardness should be similar and theres gota be some tear down videos on yourube.
Old 06-06-19, 03:04 PM
  #502
derousseau
derousseau's Avatar
Has any one found a way of installing apple play on a 2019 RX350 that doesn't have factory navigation?
Old 06-06-19, 03:13 PM
  #503
emhriv
emhriv's Avatar
@derousseau see my posts for install on non-navigation 2016 RX350. Other than the tear down of the head unit, I’d imagine that the install should be similar.
Old 06-07-19, 09:37 AM
  #504
Tungy2k
Tungy2k's Avatar
Default Help with cable routing
Hi
Does anyone have pictures of cable routing behind the headunit? Everything is working but i cant put back the headunit. I even used force without any luck. I put the box under where aircondition blows and all cable either under or on the side.
Old 06-07-19, 10:22 AM
  #505
Gottspd
Gottspd's Avatar
There's a nice space that the android box can fit in behind the climate control switches. It should slip back there and you shouldn't have to jam anything. It all fits snuggly but easily enough.
Old 06-07-19, 01:53 PM
  #506
joeguan3rx
joeguan3rx's Avatar
My installation was success
The following 2 users liked this post by joeguan3rx:
jjj666 (06-07-19), leedoobert (06-07-19)
Old 06-07-19, 02:16 PM
  #507
Tungy2k
Tungy2k's Avatar
Do you mean on top of the original navibox?
Old 06-07-19, 03:52 PM
  #508
jjj666
jjj666's Avatar
I put below the OEM unit behind the climate control button. I just pushed it down there vertically
Old 06-07-19, 05:11 PM
  #509
leedoobert
leedoobert's Avatar
That looks excellent! I can't wait till mine comes in (Monday)
Btw, you have a lot of missed calls and voicemails
Old 06-08-19, 02:15 AM
  #510
Tungy2k
Tungy2k's Avatar
Tried verticaly works perfect, many thanks! Everything was working untill i tried the USB dongle the car wont start and after Lexus logo the screen is black. Its beeping and said hybrid system is off. Anyone have same problem?
Quick Reply: Aftermarket carplay on 2017 RX350
