Aftermarket carplay on 2017 RX350
#826
Wireless charging vs Wired Charging?
So when I wirelessly charge my phone while connected to CarPlay, I see the battery charging icon on my CarPlay screen and also on my phone screen - my phone charges fine
When my wife plugs in her phone (wired) to CarPlay, the battery charging icon does NOT display on the CarPlay screen, but shows on her phone screen - however, her phone doesn't really seem to be charging (the battery percentage stays the same throughout her drive)
Has anyone seen this issue?
#828
On why battery stay the same, it’s because your phone uses an equal amount of energy it gets from the charger. The box’s USB doesnt provide much energy to charge your phone to 100%. It only keeps your phone battery percentage from dropping. CarPlay requires a lot of processing power from your phone (e.g. GPS, Bluetooth, Wifi...).
#829
I've noticed the same thing. Bought a USB voltage tester off of Amazon, should be here today. Will test the various USB ports provided by lsait and see what the charge is. But I probably will only do emergency charging through their ports. Would really love to setup a Qi charging pad but I have a RFID sticker between my case and the iPhone. Heard it may get wiped out due to the magnetic induction.
CarPlay will NOT show battery status when using wired. It only shows on wireless connection.
#830
#831
In my apartment building they use keyfob to access the gym and various restricted areas. I used KeyMe to clone a RFID sticker. Super convenient. But it prevents me from going to wireless charging. Did some research. A regular magnet plate (used for magnetic phone holders) have a static field so it should be okay to use with a case and my KeyMe RFID sticker but a Qi charging adapter uses magnetic induction which creates a non-static field which will apparently destroy the RFID settings.
#832
#833
Results are in.
I connected the wireless dongle to USB2 on the lsait. It shows 0.47 amps, which is really low.
I couldn't attach it to USB0 or USB1, since the testing device needs to be plugged directly into the output of the USB source. I'm guessing they will also show the same level of amperes.
I also have a USB cigaretter lighter with 3 connectors, 2.1A, 2.0A, 1.0A. 2.1A provided 1.94A. 2.0A did not work. 1.0A provided 0.97A. Pretty much what is expected.
I tried the 2 USB ports in the middle console. They provided 1.0A.
The following 2 users liked this post by PotOdds:
darrenph1 (09-26-19),
leedoobert (09-28-19)
#835
Results are in.
But I read on the requirement for power and it says
adapter rated 5V with a minimum output current of 750mA
#836
Hi, I see there are multiple options to choose from 7.1 carply and advanced carplay. Which one do you recommend for RX450h? Also, do you have any video of installation to share. i want to take to the car repair shop to see if they install it for me thanks!
cheers
cheers
#837
I am happy to report that my lsailt CarPlay unit works great with the new official iOS 13 release
The top 3 things I love about CarPlay on iOS 13:
1) You can now use your phone without interrupting the CarPlay interface! For example, if you are running Google Maps on CarPlay, you can still use your phone to text, browse for the next song, etc. and it won't kick you out of your current CarPlay screen!
2) Album art is now displayed next to your song in Spotify and other music apps
3) Calendar is now available as well as a new CarPlay dashboard screen
#838
I installed mine, everything works except when I put the car into reverse, it goes to the factory screen but the camera image never pops up. I have the the non-nav. Removed all wiring and restored to factory wiring and the camera shows up. My hunch is that the harness for the device is not supplying power to the camera. Checked all connections and they seemed to be intact. Software issue?
#840
