2016+ navigation screen removal?
Does anyone know how or have a link on how to remove the navigation screen? Long story short, I have a nasty rattle/creaking/ticking sound around the screen area. I have isolated it to be the plastic frame that surrounds the screen.I want to remove it and use some felt to cushion it. Trying to avoid the dealership but that would be my worse case scenario if I can't find instructions or it's too complicated to do.
Thanks for any help.
Henry
Henry
Because i this is a 2016+, the vehicle is under warranty. If I were you I would not attempt to fix this. Take it to the Lexus dealer so you don't introduce any additional problems and have Lexus deny any future warranty fix.
Henry
Henry
It is under warranty. Just want to avoid dealership if I can but I understand your concerns on future warranty claims and whatnot. Figure if it was a quick and simple thing. I rather just take it out, add some felt and call it a day.
I actually saw something on this removal recently but can't remember where although most likely on this forum. From memory it said there's a thin panel in front of the screen, pry that up and also lift the rear cover from the screen, you then find three bolts, 2 in front 1 at the rear, or visa versa, remove bolts and the screen comes away.
thanks.
Did you end up fixing the sound?
I have a similar issue on my 2016 RX, and of course it pops up after the basic warranty expired.
I've removed the panel in front of and underneath the screen and added felt tape all around it, but that made absolutely no difference so I'm thinking the noise has to be coming from the panel behind the navigation screen.
slowmotion
09-23-03 11:44 AM
