ICS Reprogram Service Campaign (certain 2017-2018 RXs)
I traded a 2007 LS460L with 80k miles that had similar error codes and a $4000 estimate for my '17 RX350 FSport that is NOW giving me the same messages and more! It's not the gas cap and I've not run it low on gas. Off to the dealer she goes tomorrow to see what the issue is. Not a happy camper! I'll update when I hear back from service.
It's happened a total of four times in July. It's in the shop for the second time. The first time they told me it was software related. I told them to either resolve the issue or I was going to have to get another car. I don't feel safe driving down the tollway and all the sudden seven messages pop up saying all sorts of systems are malfunctioning, including low brake power. To be continued...
Running a vehcle until gas runs out is bad practice. We don't know at bottom of tank is gasoline or water. I live in cold climate, we always fill tank when it has only quarter tankful left. If one stalls
car out of gas, it can become a matter of life and dead in minus 30 weather with snow coming down. When car is in limp mode it can go back to normal when the cause is remedied itself.
Update on mine... REPLACE SPEED SENSOR LH, AND HUB BEARING ASSY. COMPLETED REPLACED REAR SPEED SENSOR LH, AND HUB BEARING ASSY AND CLEARED CODE, ROAD TEST VEHICLE. SPEED SENSOR MAGNET PICKED UP FRAGMENTS & CAUSED FAILURE (Copied from service document. Sorry for the all caps.)
We'll see if this fixes it.
Wow....received the same failure yesterday on my wife's 2017 RX350 AWD with only 41xx miles on it. Error occurred during driving, ICS failure / 2 AWD engaged / contact dealer. Towed it to the dealer. Last night dealer said the engine mis-fired and caused an error. Still awaiting on the dealer feedback today. Wife is beyond mad and disappointed since Lexus suppose to be almost bullet proof. *sigh*
i just hope this won't be a common occurrence....
Go log onto to your Lexus site and look at your vehicle health report.
I now have a service campaign for my ICS system. A trip to the dealer now!
saw this when i logged in, getting close to my 15k, i was going to do the rotate myself, but might be worth getting it done at the same time. (not sure the going rate of a 15k, but guessing a rotate is much less ??![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
SERVICE CAMPAIGNS
1 SERVICE CAMPAIGN NOTICE
Campaign Date
10-31-2018Title
Special Service Campaign JLH - Remedy Notice Certain 2018 Model Year LS 500/500h, NX 300/300h, RX 350L/450hL Certain 2017-2018 RX 350/450h Intelligent Clearance Sonar (ICS) Reprogramoops, not sure why the sizing is all jacked, sorry
Thanks for the heads up. Looks like the problem only occurs in a carwash with the vehicle in neutral. I always use PARK so I am not too worried. In fact, I don't remember the last time I used the neutral shifter position. Nevertheless, I will have the software updated at the next scheduled service.
Whoops, my apologies. I wasn't even thinking about that kind of carwash. I use a brushless car wash that you drive into and park, and yes that would really slow the line down and probably remove the parking pawl from the transmission.
Dealer called me on this so I'm going in this weekend. Good opportunity to shop for the new ES I'm thinking about
