ICS Reprogram Service Campaign (certain 2017-2018 RXs)
#107
On the same issue involving my 2017 RX350, on 12/10/23 slow drive 15-20MPH looking at Xmas decorations in neighborhood, all of sudden and no buzzards the following alerts: ICS Malfunction, Check Engine, AWD System Malfunction, 2WD Mode Engaged. I cleaned sensors, they work and give warning, automatic braking system not work along with cruise control. Everything else appears to be OK. Have appointment with dealership but would like to save money if there is fix and a reason how this happened. Car has 71K miles.
#108
ravenuer (12-12-23)
#109
Returned from Lexus dealership where diagnostics test was performed. Their findings were the “Purge Valve” was stuck in the open position. Codes P017100, P017400, P04417E, P045500, P0117B00. This caused the check engine to light to come which disable the automatic braking system and cruise control. Waiting on part.
jollick (12-13-23)
LexRX300h
11-13-14 09:55 AM
ashleymari
ES - 5th Gen (2007-2012)
08-13-14 03:08 PM
