Oil Filter Cap Assembly/Cartridge
TechPro OS-011-1, my fellow co-workers mostly used the OS-011-2 but I like the 11-1 as it is slightly more of a loose fit so less likely to get stuck on a tight/dirty filter housing. These things are HEAVY DUTY and are a quality piece - designed for pro use and will take an absolute beating. If it's good enough for a Toyota dealership, it's good enough for DIY. Got it from a tool supplier that supplied to the dealership.
Yep, not sure if it is available in the USA but it makes me wonder if there is an equivalent out there made by another brand. These are great for getting over-torqued filters off, which shouldn't be an issue with a DIYer like us, but it's a good re-assurance.
This "Tool Guy" brand one looks pretty decent too. Not available over here but would be way better than the cheap aluminum / pot metal ones they sell at auto stores. If it's actually quality chrome vanadium that would be awesome. There's also the Toyota OEM (# 09228-06501) which is solid too although hard to find now. There's a nice US-made one on eBay too which is aluminum but it's real nice 6061 series aluminum and looks proper as well.
https://www.ebay.com/itm/Oil-filter-...-/173035944655
The Motivx Filter Wrench and Drain Tool are great for changing the oil. I just did my first oil change at 4000 mi.
https://www.youtube.com/watch?v=_MfbXtaVCPg
nice write up... ? are the 2022 RX350 the same as this 2016 as far as the under neath I like the idea not having to remove shields to access the drain plug and filter..
I haven't crawled under mind yet, it's no where near it's first oil change
Thanks
Xbow
jollick (12-07-22)
jollick (12-07-22)
I use the same Ultra Platinum oil (we probably both watched the Project Farm vids... ), but never find it in stock in auto parts stores. Amazon and Walmart.com are the only places I've found it.
