Change the factory brake system to a factory GSF brakes
I have a RX450H 2017 BUT I WANT TO CHANGE THE BRAKE SYSTEM FOR A GSF BRAKE SYSTEM CAN SOMEONE LET ME KNOW IF I CAN DO IT
I want to change the factory brake system to a factory GSF brake system I want to know if is possible
Another thing to consider is the hit you're going to take on resale value.
Carlo, above all check with your Lexus dealer. These days everything is more complicated due to the technology that's intertwined into all aspects of the vehicle. Second if you decide to go ahead let the Lexus technician perform the task IMO it's way too complicated & complex to be undertaken by a novice (I assume you are not a mechanic).
Since hybrid braking relies on the motor generator for the initial and most light to normal braking down to about 7 mph, it would likely be quite complicated and may not be getting you the result you want.
ok thank you for let me know this I think I will leave it like This
What part of the braking system are you looking to change and for what exactly is the reasoning?
While the GSF wont be a direct fit, it never hurts to seek each of the parts on the system and compare parts.
Lexus082
Suspension and Brakes
02-20-13 12:28 PM
