Headlights condensation
This is in the '18 manual:
■ Condensation build-up on the inside of a lens
Temporary condensation build-up on the inside of the headlight lens does not indicate a
malfunction. Contact your Lexus dealer for more information in the following situations:
● Large drops of water have built up on the inside of a lens.
● Water has built up inside a headlight.
2016 - RX350 - Deliminating headlight clear coat and water in head light
A family member purchased a L/certified Lexus 2016 RX350 recently with about ~20,000 miles and still has original factory warranty (6 months remaining). I noticed that the headlight clear coat appears to be delaminating and the passenger side headlight also accumulates condensation inside the assembly when washed. (see attached images)
Has anyone else experienced these issue? And if so, have you gone to a dealership to address these issues? Many thanks in advance!
Wow, Lexus has not killed the issue on condensation on headlamps. The truth is, the OEM maker of the headlamps is other than Lexus. So failures can happen and if Lexus is not diligent in chasing after their suppliers, a possible recall might happen again.
