Can you reprogram a used keyfob?
Can you buy a used keyfob and get it reprogrammed to your car? I called Lexus and they said a used key fob won’t work and the keyfob must be bought from them. Is Lexus BSing me? Thanks guys.
As long as you have at least one working keyfob to the vehicle, you should be able to have a used one reprogrammed to the car. I had a Toyota 4Runner limited that I had to get a used key fob for and my toyota dealer programmed it for me without issue. It was also the smart key system, so I can't imagine the lexus dealer can't do the same. I'd check with another dealer, personally. There should be no reason you have to buy the fob from them as long as it's the right type for your vehicle. The laser cut key in the fob might be more problematic.
From my understanding having done this myself on a 2006 GX there are 3 aspects of key setup:
1) Immobilizer enrollment
2) Keyless entry enrollment
3) Actual keyblank cutting
Obviously you'd have to get a specialized locksmith to get you a replacement keyblade and cut it. This is normally not to cheap, but some locksmiths may be better than others, it's an expensive machine they need to have access to. Nothing to do with lasers, it's milled regardless what they call it.
Otherwise on issues 1 and 2 as previously mentioned it should be doable with the techstream software and some time. However many dealers have "policies" which are intended to be enforced for whatever reason. Likely to make them more money by insisting you buy a new blank from them (they even sometimes re-use them also).
I was able to reprogram a used key fob with an OBD2 device off Amazon. As long as you have an existing fob that's programmed, you can program a second used one.
ravenuer (12-14-23)
yeah, I see why these vehicles are so easy to steal.
I just had a local locksmith order a blank key and then cut it to match my existing one. Cost total $36.50. I admit I'm a little **** on keys and fobs. I have 3 complete sets of fob and key. 1 I use every day. 1 is my backup in the house. 1 is locked in my trunk where I can get to it if I lose my carry while out and about by unlocking the trunk. I have the extra key hidden under the car where I can get to it to unlock the car and open the trunk.
autotech13 (12-16-23)
Did you use Techstream or something else to program the key? I'd like a third key but not enough to spend $500. Thanks!
Desaparacedos (04-03-24)
babbles
ES - 6th Gen (2013-2018)
15
09-16-19 12:23 PM
