2017 RX Quick Dial Settings, need help?
In my 2017 RX, on the far right hand side of the navigation screen. Their are saved phone numbers with names. I need to remove one of the names and can't figure out where to go in the settings.
Please help. Thanks.
If I understand you correctly, go to you list of contacts, find the contact that you want to erase and uncheck favorites.
I don't think that will work.
Instead of removing the contact, I edited the fields so she has a new phone number. Her name is no longer there but the number that I deleted in the contact field still remains.
There has to be some way to get to Quick Dial settings in the vehicle.
The main phone screen will list up to 2500 contacts, you may turn the left side gray star to a gold star
by selecting and pressing down or using your thumb on the side key to denote up to 15 Favorites.
When you open the right side screen to Quick Dial you "Add from Favorites" and select the number
from the Contact to save. All of this effort seems most appropriate when the Contact Name is tough
to pronounce such as "ABC Medical Center Third Floor Nurses Station SW" and you don't want to
screw around with verbal commands. All of this background is for those that have not utilized Quick Dials...
OP's answer is simple, select the Quick Dial you with to remove and Press and Hold your remote button...
you will get a dialog box to confirm that you want to delete?
RJPLexus
RX - 3rd Gen (2010-2015)
04-02-13 05:52 AM
