Lexus Anti Collision System
I guess I'm unsure what systems are functioning or not functioning in these various tests: Intuitive Parking Assist (sound and display only), Intelligent Clearance Sonar (low speed front and rear braking for stationary objects), Pre-Collision System (higher speed front detection and braking, and/or Rear Cross Traffic Auto Braking. Add to all that the difference between detecting pedestrians as opposed to cars or buildings. If you look at the full manual, each has a number of specific situations where the system may not operate, as well as explanations where it should. Some camera, some radar, some sonar. The seat belt issue is not addressed that I can see in the manual, but these belts also have pre-tensioning which can activate prior to impact. Best advice, as above, is wear the belt but it may also be worth looking at the speeds and situations where each is intended to operate, or not, and how to really conduct a precise test.
That is silly and superfluous answer. Of course I made a mistake. The point is that safety systems are built to protect people whether they are being safe or otherwise. Toyota's has much to say about owner responsibility, but they still provide systems that used in conjunction with safe drivers will protect people. However, all the disclaimers being duly noted, why would Toyota choose to not operate the system if a safety belt is not engaged? I suspect that it is a design issue that needs to be corrected, or documented that the system is not engaged when the belt is not engaged. Furthermore, I used Carista to turn off the warning, because I have a long driveway and want the capability to back the car out from time to time to park it on the street. It seems to me that the Carista option should not be available if they do not engage the protection systems if the belt is not engaged.
mspearl95 (08-23-19)
No I don't. But I did learn a loooong time ago how to drive a car without having to rely on the computer to stop it for me.
dchar (08-23-19)
coolsaber
RX - 4th Gen (2016-2022)
38
04-01-16 10:43 AM
