Lexus Anti Collision System
Hi All, just a word of warning.
I did a test to see if the Anti Collision System works without the seatbelt being on and it doesn't, did it twice and both time it touched the plastic barrel I used as obostacle, did again with seatbelt on and it worked as intended.
I did not try that in reverse gear.
Thought to mention it before someone gets into an argument with an immovable object
jonathanz (08-21-19)
Was there an audible alert before it hit the brakes when your seatbelt was fastened? I could understand that the automatic emergency braking will be disabled if not buckled in otherwise a driver or passenger could go flying into the windshield. But it is inexcusable for there to be no warning alert (audible and visual etc) regardless of being buckled in or not. My Pacifica PHEV would blast a warning tone and the entire dash would light up if the system predicts an impending crash, buckled or not. What if I had heavy boxes sitting on the rear seats? Would these critical safety features be disabled because the vehicle thinks someone is sitting back there unbuckled?
Cocal (08-21-19)
the perimeter radar park assist didn't make any noise either ?? what speed were you testing at ??
mine goes off without a seatbelt, many times i park on the driveway then later pull it into the garage without a seatbelt.
different system it sounds,
The perimeter and front radar worked OK only the auto braking failed, I tested it twice and failed twice then I buckled up and tried again and the auto brake worked as intended.
I don't wear my belt if I'm moving the car say, from the driveway into the garage, but my issue with that is the parking sensors/auto braking, or whatever it's called. I have a tight garage and when I start pulling in, it goes nuts beeping and booping! If I go anything over a half mph, it'll apply the brakes. Annoying, but not the end of the world!
My concern was that it would not apply the brakes at all if unbuckled and you wanted to squeeze all the inches to have some space behind.
When buckled-up no problem, I mentioned it as a warning so that everyone knows and will not run into a wall.
ravenuer (08-22-19)
The same thing happened to me last night while backing down my driveway. There is a car that is always parked on the other side of the street just opposite my driveway. I did not have my seat belt on, and was not paying attention. I tapped the other car (no damage to either car). I am going to find a way to test this and verify that it does not work. I know the braking system works when the seat belts are on, because it has stopped both our Rav and RX. This is a software error that Toyota should look into and issue a TSB for all vehicles.
Cocal (08-23-19)
you pay for all the extra safety systems... you expect them to actually work in all circumstances.
I guess I'm unsure what systems are functioning or not functioning in these various tests: Intuitive Parking Assist (sound and display only), Intelligent Clearance Sonar (low speed front and rear braking for stationary objects), Pre-Collision System (higher speed front detection and braking), and/or Rear Cross Traffic Auto Braking. Add to all that the difference between detecting pedestrians as opposed to cars or buildings. If you look at the full manual, each has a number of specific situations where the system may not operate, as well as explanations where it should. Some camera, some radar, some sonar. The seat belt issue is not addressed that I can see in the manual, but these belts also have pre-tensioning which can activate prior to impact. Best advice, as above, is wear the belt but it may also be worth looking at the speeds and situations where each is intended to operate, or not, and how to really conduct a precise test.
It's not a question of fault; it's a question of...shouldn't the auto brake system have stopped the vehicle! IMO it should have, but the system doesn't work if the seatbelt isn't buckled-up. Do you buckle up to move the vehicle a few feet?
mspearl95 (08-23-19)
