Sanity Check On Something
The nail could well be true, just because the pressures were good doesn't mean the nail wasn't there, it may have been in tight and not leaking or not all the wall in yet. Saying it needed an alignment again could be true, you wouldn't know from just looking at the car. The service cost, well, sounds a lot for the US. I'm in Australia and the services here are around 700-800 AUD every time. (470-540 USD), but then we get burnt on most things here.
This whole thing sounds like a complete ripoff to me. He would do well to never darken their door again.
Gunny, Thank you for your service. I'd say they definitely did wrong by you. I would gather all supporting documents and schedule a meeting with the service manager. Explain your concerns with the situation and see if they will make things right. I would also make it clear that if you were to ever return there you want to be notified of any additional services or "recommendations" in advance.
They've tightened the standards for plugs/patches in the past several years, sidewall and a good portion of the lateral tread: (US Tire Industry Assn)
Puncture repairs are limited to the center of the tread area. If there are punctures or damage in the shoulder or sidewall of the tire, it is not repairable.
As most of us know, a nail in a tire is an easy, quick repair unless it is in the sidewall area, in which case a new tire would be needed. An alignment because of a nail in the tire! Unforgivable, as is the failure to show the damaged tire.
GunnyFitz (09-26-19)
Sidewall My A**!
Thank you for posting this. Its 100 times easier to see it, than explain it. Their new "Guidelines" are clearly money makers! See that "Blue Line" on right side of Tire? Well THAT was where a small hole was upon visual inspection of the tire - and IMHO that does NOT constitute the "Sidewall" of ANY tire! They took advantage of her with their carefully manipulated style of Upselling -which I note is their jobs.
They did not put HER face to MY name and background with this Co. I'm no zillionaire like Crabtree, but I'm not adversary you'd wish for when ti comes to integrity violations!
Bottom line. They Compd the whole mess when I dropped a number of Corporate names given to me from my good friends in Brooklyn, where the RCF came from - Remember that story? LMFAO !!
I would first call the local GM. No satisfaction than Lexus Corporate. When i have made these calls got great results. I do not not even take my vehicles in for the off 5,000, 15,000, 25,000 mile service. This is just a tire rotation. I rotate at every 10,000 miles if the tires are wearing evenly.
I pay less than $410 each for our ES 300h and RX 450h for every 30,000 miles. I never go in an ask for a 10,000 miles or 30,000 mile service. They charge ridiculous amounts for a lot of inspection of things that do not need to be inspected. Every 10,000 miles the oil needs to be changed. Every 30,000 miles the brake fluid needs to be changed. At 30,000 miles the cabin and air filter need to be replaced. I do mine at 20,000 miles and cost $45 for both and take 5 minutes to change. Every 20,000 miles I replace the wiper inserts at $15 and again five minutes to change.
Ditto as above thanks for your service.
Everyone needs to have a tire patch kit. There's many versions on Amazon.
You need the patch tools, patches, glue, and needle nose plyers, tire inflator, Depending on what you have, decides on what you need to buy. If you have needle nose plyers and a tire inflator, then buy the patches and tools.
I just rented a car, was driving away, and the tire pressure light was on in the car. I went back home and sure enough, there was a nail. I patched the tire, pumped it up, and drove away, no problems the entire trip.
Its' a funny story, because I remember buying the patches a few years ago. I bought a 20 pack thinking it would last forever. They are almost gone now. It seems I patch a tire every few months. See, here's 30 repair strings. I need to buy this again.
BUY A PATCH KIT and PORTABLE TIRE PUMP. Buy a 30 pack of repair strings, you will use them. It's not hard to patch a tire. There's YouTube videos that show you how. Oh, and the rubber cement, I bought a bigger jar of it.
The little tubesof cement don't last long. Get a big jar of it.
https://www.amazon.com/s?k=tire+patc...f=nb_sb_noss_1
https://www.amazon.com/CK-Auto-Autom...ateway&sr=8-41
https://www.amazon.com/Slime-1050-Ru...ateway&sr=8-11
The little tubes don't last long. Get a big jar of it.
GunnyFitz (09-30-19)
Agreed GRJFER - THAT is the ONLY way to know any hoe has been patched correctly, and IMHO should've been done instead.
May as well close this Thread down since the after my Cool Down period I paid the Service Director a visit and resolved this issue - well, mostly....
ravenuer (09-30-19)
Pearlpower
CL of Southern California
18
12-14-05 03:45 PM
