I picked up an 18 RX350 CPO last week and can't figure out how to recenter the vehicle position on the map once I moved it, usually by accident via the joystick. I've tried the "back" button near the joystick, I've looked in the menu... please help!
Mmmm......try pushing joystick down on the map (make sure the map is the active screen) and then push Map button. If not working maybe an issue with the switch under that Map button. I think I saw someone on here recently that had an issue with that switch.
I have the 13inch Nav Display. And you have to put the cursor on the side you want to make changes. The first time it happened to me I waited to restart the car. That's when I figured it out.
