Sometimes I can just touch the door handle and all the doors lock and the mirrors turn in. Other time I touch, grab, stab and finally get the fob out to lock the doors and turn the mirrors in. So, what am I doing wrong? Really like the touch feature………when it works!
Bill
Mine always works. Only thing I can think of, is the fob fairly close to the car and not blocked by anything? Also, are you just touching the "crease" at the rear of the door handle? If you "grab" the handle it will want to unlock. Never tried mine with gloves on, so there's that.
Bill
If you fold the mirrors in every time you shut off the car, you can set it up that way. Find the sensor on the front of the any door handle and quickly cover it with your palm, if that doesn't work take it to your dealer.
Sounds as if I am doing it right, could be the fob battery, but am not getting a message on display. Rear hatch touch doesn't work either, but I can live with using the fob, dealer is 70 mile away.
Bill
You can get a battery at the drugstore, it is very standard: CR2032.
You extract the key from the FOB and use the tip in a slot inside express for it to open it.
Bill
No such issue with mine. I would change the battery since that is the cheapest option and see if things get better. If not, you have some sensor issue. I would bring the car to the dealer since that is a big inconvenience and will hurt later when you need to sell the car (assuming you have factory warranty now). Good luck
