2016 rx 350 clicking noise under dash
I'm hearing a fast clicking noise under the passenger side dashboard near the glove compartment on my 2016 RX 350 with 48,000 miles.. It stops when I press the outside air button to stop the air recirculation. I think I recognize this noise as a blend door actuator issue as I have replaced many on GM vehicles. Can someone enlighten me on how to replace this part? I couldn't find the part on Ebay.
Thanks
Brian, New Member
Thanks
Brian, New Member
Thanks
Brian, New Member
Thanks
Brian, New Member
To be honest since the warranty has just expired I would bring it in anyways. Lexus is all about customer service as there mission statement says "Lexus will do it right from the start. Lexus will have the finest dealer network in the industry. Lexus will treat each customer as we would a guest in our home."
The dealer may sell you a car, but its the customer service that makes a return customer. Five days out of your warranty, I would still bring it in. Customer retention is a must, at the most they will cover the cost since you're so close to the end of warranty, there is a forgiveness period. When I had a VW that had just run out of warranty they covered half the cost of labour and covered the cost of parts. But anything they will cover will be to your benefit.
Bottom line is bud, if you don't ask you wont get anything. And these companies do have programs for peoples warranties that have just expired. It should cost nothing for you to drive the Lexus in and ask, but the longer you wait then the farther you are out of that warranty expire grace period. I would be shocked if a dealership wouldn't be willing to work with you on a car so soon off warranty.
I know this isn't the answer you were looking for, but I believe getting it in there promptly to possibly take advantage of these just past warranty grace periods is important, and may save you quiet a bit of $$$.
I will call the dealer and ask if they will honor the warranty, however I don't expect they will fix the issue due to an expired warranty. I have had no issues at all until yesterday when the fast clicking noise started. It makes the noise when I first start it and the fresh air button ( green light) is on. If I push the recirculator button the noise stops. it only makes the noise in fresh air mode. it appears the hvac system works properly other than the noise. I am extremely mechanically inclined and am confident I can replace the servo or actuator myself after I figure out how to get at it and actually feel which servo or actuator is clicking. Can someone let me know the procedure to get at the area. I'm assuming I would start with the glove compartment door and some air ducts. just looking for info from someone that has replaced the passenger side servo. I believe it would be part number 87106-0E100. any help would be appreciated.
Thanks
Brian
Thanks
Brian
Thanks
Brian
Thanks
Brian
Talk to the boss and tell him what you have learned about the issue and then bring up the warranty. Be direct, he'll either say yes or no.
In general, people like to help other people, I know I do and after all it is Christmas.
SilverFire (12-20-19)
LenniePaz
08-31-11 07:47 PM
