Where to Purchase Key Fob
Use this youtube video below as your instruction. Way too easy
I bought the techstream and cable on ebay. Took about 15 minutes to program my new virgin key. I installed the techstream software on my windwows 10 64bit. No issue. it runs just fine.
https://www.youtube.com/watch?v=FmY-yBvYCvg
if you have windows 10 64bit, use the instruction from the 64bit folder.
https://www.ebay.com/itm/Mini-VCI-Di...72.m2749.l2649
2nd key fob not working
Hey gang - we picked up a '16 RX350 a few months ago - love it. We received two key fobs with it. However, one of them doesn't work. I figured it was just the battery and so I replaced the battery in both fobs. The one works fine, but the second one still doesn't work at all. I've tried the trick where you hold it close to the start button or whatever, and that didn't do anything. Is there any way to program the fob with one working fob or is this a dealer-only thing? Both fobs are original Lexus fobs. Can a Toyota dealer do this or does it have to be Lexus?
Key Fob replacement
Whats up guys, looking at purchasing a 2017 RX350, however it only comes with one key fob. Local dealership will program for $80 but wants over $300 for the fob and key insert. Is there a better route to go for the fob and key than the dealership? if so can you guys point me in the right direction? thanks all!
Ebay $89.49 reputable seller, refurbished OEM, For 2016 2017 2018 Lexus RX350 RX450h Keyless Remote Key Fob HYQ14FBB G Board
or OEM $118.59 https://www.keylessentryremotefob.co...Fob-s/8448.htm
The key code is Fob HYQ14FBB G Board, 2 ideas
