Thumping sound from my 2019 RX 350 - PLEASE HELP!!!
Hello RX Lexus owners!
I'm a woman and don’t know anything about car. I bought my brand new 2019 RX 350 last July 2019. After about one moth after purchased I started to hear rattling noise from the driver door trim panel and the center cup holders. I have been taken it to Lexus dealership 3 times for the same issue. The noise has been significantly reduced though it’s still there but I can live with it.
My major concern is about the thumping noise from the back of my car. I noticed the thumping noise came up for the first few rides after I filled up my car. I noticed the noise pretty loud when the car was idle when I stopped at traffic or when I backed my car into the garage. I took my car into the dealership they replaced the center exhaust. Then yesterday I filled up my car again and the noise came back. I scheduled a service appointment with Lexus again for tomorrow. They wanted me to do a test drive with them when I come in. However, the problem is the thumping noise is hit and miss. Since I’ve been driving several times after I filled up the car yesterday, the noise may go away by tomorrow then I won’t be able to replicate with noise for the Lexus technician.
If any of had this problem before please let me know what it was so I can suggest that to the Lexus.
Greatly appreciated any inputs.
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
Please see if you could be able to detect the sound from this recording that I recorded last month.
not able to attach the video for some reasons.
Hi DMPesso, thanks for responding. The noise occurs when idling and driving (when I backed up my car into the parking lot). I could hear it loud and clear when idling or parking. When I drove with other surrounding noise I wasn’t able to tell.
no need to reproduce it in front of them
Denzo (11-08-20)
does it sound like its coming from the bottom of the car by the exhaust? I just reread your post it seems you have vibrations in the cup holder and door that’s usually tied to the droning from the exhaust. My guess is it’s your transmission or the exhaust. My car used to jerk into gear when I would put it in reverse but I don’t recall it doing anything while idling. The TSB helped quite a bit. Try putting the car in sport mode and tell me if you notice it as much. Also try using 93 gas and see if it goes away. You should look into getting the TSB for the hesitation done as well.
are you able to tell what part of the car the noise is coming from? Are you sure it’s a “thumping”?
And yes, starting my last fill up I used the premium 91 gas at Chevron. There’s no 93.
Good idea. Tigey, can you have someone sit in the back seat and lower the other seat and have them record. I did this when my RX was making a ticking noise. Service Manager heard it and said you have air in your brake line. He was right. I had noise in the door panel coming from the storage area and things sliding around. I put a small rag in the bottom of the compartment and it cured the noise.
Thanks!!!
Thanks!!!
https://redirect.viglink.com/?format...53199-9999.pdf
Aposan40
04-20-18 11:10 AM
gholla
RX - 3rd Gen (2010-2015)
17
07-01-17 11:19 AM
