Chip on Rear Tire - Safe to Continue Use? (Bridgestone Tires on 2016 Rx)
I was washing my 2016 Lexus RX today and noticed that one of my rear tires has a chip on the sidewall. Photos below (click on them to zoom in).
These tires have approx. 38000 km (24000 miles) on them, and have about 7/32" tread left.
Is it safe to continue using this tire?
The sidewalls are not as thick as the tread. If I were you I'd replace it. If you run at high speeds for a continued length of time you might weaken or blow out the tire sidewall. What tire pressure do you run at?
bee144 (04-20-20)
I will bring it to a shop for an in-person opinion sometime over the weekend, if I can find one that's open.
How thick is the sidewall on a tire anyway? Trying to figure out how much of the sidewall this chip has actually penetrated through.
I don't know the thickness but whatever it is I'd prefer to have all of it.
ravenuer (04-22-20)
swfla (04-24-20)
Everyone here wants to help, but I'd go with tire shop advice over member opinion. Just keep an eye in it, there are several layers of belts on the sidewall. BTW, If you hit a deep pothole at 80 mph, there's a good chance that ANY tire will fail and bend the rim, using you to do several 360 degree spins.
Since you are experiencing fantastically great tire wear, I would just drive on that tire. Most of us have worn out our Bridgstones by 24k, and have moved on.
