Screw in tire
I have certificates on my tires so Discount will always patch for free and then balance free. However, I have put insert plugs in the tread where a nail or screw has been removed many times. Never had any of them leak again. If my tire was still pretty good, I would do it again.
If you have a tubless, you could always add some Ride_On as a backup:
https://www.ride-on.com/us/support/t...es/car-formula
ravenuer (09-13-22)
You, and your UK Costco, are right. It is a common misconception that the best tires should be on the front on the vehicle. I think the theory is that it helps with steering. "Studies have shown," though, that non-professional drivers are significantly better at handling understeer situations than oversteer. When the rear end starts to slide in a turn, very few non-professional drivers can correct for it.
