No Fog Lights
#61
From an online article they said that the 2022 RX350 has a standalone option for fog lights. I just got a 2022 RX350 and I will check with my Lexus guys to see if that is the fact and whether the wiring might be in the harness.
Most significant changes: The 2022 Lexus RX SUV carries over with new paint colors and a standalone option of foglamps for all trim levels.
from Cars.com:
https://www.cars.com/research/lexus-...CAAEgJTDvD_BwE
2022 Lexus RX 350 review: Our expert's take
By Fred MeierMost significant changes: The 2022 Lexus RX SUV carries over with new paint colors and a standalone option of foglamps for all trim levels.
from Cars.com:
#64
Working on getting my girlfriend a new 2022 Rx 450H. The car-pocalypse is a bear, but we found her one that gets built on 6/3/22 and she's reserved it. Fortunately, this allotment will be configured almost exactly how she wants. But there's a single hitch. It will have the base headlights, tail lights and no fog lamps.
I've seen a few posts out there on upgrading other lexus headlights. Has anyone out there upgraded the headlights to the triple beam LEDs on the 2020-2022 Rx? Is anyone out there with the base headlight RX willing to take a look to see if the fog lamps can be bolted into the front bumper/ does the wiring harness on the base lights support it?
Looks like I can snag a used set of triple beams for ~$1200 and fog lamps for $300 more.
#65
Will not work because our triple beams auto level and the single projector style does not and is not programmed to be able to function that way now you can install the headlights yes but they will be facing towards the ground since by default the headlights start at that position when the car is off and then adjust themselves when the car is turned on.. which is more then just a wiring it’s a complete software that the vehicle must already have programmed in order for that to even function properly..
#66
Hi folks - we have a "loaded" 2020 RX350 (including the Luxury Package) and it has the triple beam headlights and the fog lights. Trust me, the fog lights are beneath a nothing-burger. While they look somewhat cool there is, in my opinion, no compelling functional reason to expend any energy at all in researching them or trying to install them. All that they do is illuminate a few feet of road in front of you and the "cornering lights" are, other than telling someone else that you are turning, useless.
The following 3 users liked this post by Marty2020:
#67
#68
Cocal (05-29-22)
#69
#70
Actually pretty close to what I'm looking at doing. I want to mod the fog lamps onto my car. Already bought the factory fog lights and turning lights. I might be too difficult to install them as fully factory functional. At least no one has figured them out yet. So I figured I just put them on a switch in the dash. At this point, I think they'll just be installed with a fuse jumper and come on as always on when the headlights are on.
#71
#72
#73
#75
I have the so-call 'fog lights' on all of my current vehicles. They illuminate a few feet in front of the vehicle. If you really need that part of the road to be illuminated, you're in trouble.
Did you actually try this and find that it helped? In what way?
For one of the vehicles, I modified the fog lights, installing the same bulbs used for the headlights. That didn't improve the usefulness (or rather, the uselessness) a bit.
TechNut (07-30-22)
