Key Fob Low battery warning for a good battery
raylor4 (02-10-21)
The battery tester typically does not load the battery down, just looks at the voltage with no load. Some batteries fail early by not being able to supply the voltage when a significant load is present. This typically this occurs in cold weather or excessive heat.
Key FOB not detected in Vehicle
On my 2016 RX450h I have been getting this notification, happened 3 times in last couple of weeks.
Today, it happened and then Key FOB battery low.
It happened after I started the Lexus and was driving.
That is when I noticed the above.
It eventually cleared itself.
Tested battery, 100% good, just been changed as part of a recent service.
What is going on?
Comments?
Thanks
What is going on?
Comments?
Thanks
raylor4 (02-12-21)
A battery tester just measures the voltage with no current draw. When batteries reach their limit, they tend slowly drop the voltage with no current load. But old batteries drastically drop the voltage when significant current is drawn. Also, temperature affects how much current they can supply. At low temperatures, batteries tend to fail to supply enough current.
Key Fob Low warning (2022 RX 350 AWD)
I changed out both Fob batteries and still getting the warning on my Lexus App... any ideas? Thanks.
Both are new Energizer Lithium batteries now, but warning stays.
I did log out and log back in on the App.
By the way, the Lexus web site isn’t any better. When I log in, it states I have no vehicles, yet it won’t let me add a VIN because the “vehicle is already added!” Good grief. They make cars and should outsource their IT systems to qualified professionals.
