Cell Phone charge port
last i knew the usb ports charged at a very slow rate, .5a i thought...
better off with a stand alone adapter.. i have a samsung so i can use the quick charge... this is what i use.
Cocal (08-13-20)
https://www.amazon.com/AUKEY-Charger..._dp&pldnSite=1
Thanks for the reply!
All of the charge points should draw the same amount of current since it’s the device that determines the draw.
The only thing that I miss from my explorer is it had a rapid charge USB port in the front. The RX uses the same slow USB ports everywhere. I use the usb in the center console the cable won’t snag under the lid since it has enough wiggle room you won’t short the cable out. In the back I use one of the cigarette lighter to dual USB adapters for the kids iPads.
I had a loaner 2020 RX and they replaced the cigarette lighter outlet for USB ports which is cool. The best part was the cell phone pocket they now give you next to the shifter! What would be really cool would be if they fitted a wireless charger into that pocket though.
Cocal (08-15-20)
