A/C Defaults to Recirculate on Startup
If you use auto mode, it'll switch from recirc to fresh air at 72 degrees.
I use the auto mode all the time. Works well. It helps keeping pollutant, smells, and smog out of the cabin. Wished there was a way to set sensitivity, so it would react a little faster.
Pretty sure I will hate it when I get stuck behind a dump truck and forget to turn it off haha
Although mine is on the most sensitive level and I don't notice much of a difference in how it operates compared to a lower sensitivity level when I leave it on AUTO.
Disregard.
